GWR Greg Posted September 17, 2015 Share Posted September 17, 2015 Since reinstalling RM I cannot save changes to ini. File. I can copy into the file as I get a pop asking me to copy as administrator. Link to comment Share on other sites More sharing options...
Hairy Posted September 17, 2015 Share Posted September 17, 2015 Hi Greg,It looks like you need to change your permissions. Right click on the ini. fileSelect properties Select the security tabClick on editIn the group or user names box click on users.In the permissions box put a tick in the modify allow tick boxClick Apply.This procedure worked for me using Windows 8.1, different versions of windows might have a different procedure. Hope this helpsChris Link to comment Share on other sites More sharing options...
Chrissaf Posted September 17, 2015 Share Posted September 17, 2015 If Chris's solution doesn't work for you, then try this:Navigate to "notepad.exe" right click this file and choose "run as administrator". With notepad running use the 'open file' menu option to load 'railmaster.ini' file for editing. Make your changes to 'railmaster.ini' and save. Link to comment Share on other sites More sharing options...
HornbyRailMasterSupport Posted September 17, 2015 Share Posted September 17, 2015 We have made life a little easier for you in editing the RailMaster.ini file. Ensure you have downloaded and installed the latest version of RailMaster from www.powerpos.com/rail-master/rm_setup.exe. Go into the Help/About screen and you will see a new small cog icon at the bottom-left area of the window. Just click on it and you will be able to edit the INI file, unhindered by Windows system permissions. Link to comment Share on other sites More sharing options...
RB51 Posted September 17, 2015 Share Posted September 17, 2015 Just had a look at this. Very good idea HRMS. A good pro-active amendment, well done. R- Link to comment Share on other sites More sharing options...
RDS Posted September 17, 2015 Share Posted September 17, 2015 Thank you HRMS, for this information and it sounds very useful but is this advice given in RailMaster anywhere.For example, I downloaded v1.62 and without knowing this shortcut, I checked the .ini file manually, through the windows system. Link to comment Share on other sites More sharing options...
Chrissaf Posted September 17, 2015 Share Posted September 17, 2015 Just to add a little bit more detail to HRMS's last post. I installed the auto-update version 1.62 about 7.30pm UK BST this evening. This auto-update version showed it to be revision 0. Seeing HRMS comment above I looked but could not find the cog referred to. Subsequently I did a manual download and fresh install as HRMS instructed in their post. The freshly downloaded version does indeed have the cog present. RM however still reports the application as being at revision 0 and not revision 1..My deduced conclusion therefore is that the .ini editor has been added very recently indeed. It would be interesting to see if the online auto-update version has also been updated to include this additional .ini editor..PS - I've electronically searched the revised 1.62 manual and can not find any reference to this editor tool mentioned in the manual. This gives weight to my deduction that this addition is a last minute modification implemented after the 1.62 version manual was written. Link to comment Share on other sites More sharing options...
GWR Greg Posted September 18, 2015 Author Share Posted September 18, 2015 Once again HRMS have made life a easier, excellent. Link to comment Share on other sites More sharing options...
St1ngr4y Posted September 18, 2015 Share Posted September 18, 2015 I've mentioned this elsewhere in the Forum, quite a while back - why don't they just do away with the .ini file, and put all of the items defined therein into the System windows of RM. They could quite easily be set up in two or three new "tabs" in that window. Using a .ini file, to me, seems archaic.Ray Link to comment Share on other sites More sharing options...
HornbyRailMasterSupport Posted September 18, 2015 Share Posted September 18, 2015 Most of the settings in the RailMaster.ini file should not need changing and changing them without knowledge can cause all sorts of problems that then makes it very difficult to diagnose errors. That is why we, and may other software developers still use ini files. Link to comment Share on other sites More sharing options...
St1ngr4y Posted September 18, 2015 Share Posted September 18, 2015 Most of the settings in the RailMaster.ini file should not need changing and changing them without knowledge can cause all sorts of problems that then makes it very difficult to diagnose errors. That is why we, and may other software developers still use ini files.So you think it's safe enough to have things like Com Port, Baud Rate, Data Bits, Parity, & Stop Bits easily accessible in the System Settings window, but critical things like Tipper speed & Turntable Time are much better kept out of easy reach in the .ini file ? tic :-) Ray Link to comment Share on other sites More sharing options...
