WilliamDavid Posted September 24, 2015 Share Posted September 24, 2015 I have just upgraded to this and can't get these functions to work.Quote.'If you have installed the optionalPro pack you can drag the loco controller by placing your finger anywhere inside it (I don't get this, can anyone explain?) as well as launch two large pop-up controllers.(This is ok)You can also select a new loco directly by entering its DCC ID while in pop-upcontroller mode. To do this, simply click on the DCC ID box. A numeric keypadwill then appear and you can enter the DCC ID directly using the keypad whichnow appears.' Can't get this to work. Link to comment Share on other sites More sharing options...
Fishmanoz Posted September 24, 2015 Share Posted September 24, 2015 Do you have a touchscreen WD? Won't be able to get your fingers into anything without. Should work with your mouse instead though. And have you emailed HRMS to report the failures? Link to comment Share on other sites More sharing options...
WilliamDavid Posted September 25, 2015 Author Share Posted September 25, 2015 My tablet is touchscreen, and I can enter the new numbers, but the panel doesn't change to the new loco.I'm sure it did work when I activated Propack, but then didn't.I have completely uninstalled Railmaster and then reinstalled it. No change. The only link with the previous instal was the transfer of the old Resource file to keep my locos.I have contacted HRMS, but they have not seemed to understand the issue.Can anyone with Pro try it to see if it works on theirs? Link to comment Share on other sites More sharing options...
AncientMariner Posted September 25, 2015 Share Posted September 25, 2015 My tablet is touchscreen, and I can enter the new numbers, but the panel doesn't change to the new loco.I'm sure it did work when I activated Propack, but then didn't.I have completely uninstalled Railmaster and then reinstalled it. No change. The only link with the previous instal was the transfer of the old Resource file to keep my locos.I have contacted HRMS, but they have not seemed to understand the issue.Can anyone with Pro try it to see if it works on theirsSame here - the number panels pops up- the numbers can be entered, but nothing is actually changed. AM Link to comment Share on other sites More sharing options...
WilliamDavid Posted September 25, 2015 Author Share Posted September 25, 2015 Totally removed all traces of Railmaster and reinstalled from above link.No difference. Link to comment Share on other sites More sharing options...
WilliamDavid Posted September 25, 2015 Author Share Posted September 25, 2015 My local Model shop owner has just tried his and it works fine.His is, I think, an older version of RM.Can 1.62 be the problem? Link to comment Share on other sites More sharing options...
WilliamDavid Posted September 27, 2015 Author Share Posted September 27, 2015 My local Model shop owner has just tried his and it works fine.His is, I think, an older version of RM.Can 1.62 be the problem?Turns out his doesn't work either, and his is on 1.62.Must be a fault with the 1.62. Link to comment Share on other sites More sharing options...
HornbyRailMasterSupport Posted September 27, 2015 Share Posted September 27, 2015 We are currently investigating this and will have an update shortly. Link to comment Share on other sites More sharing options...
RDS Posted September 27, 2015 Share Posted September 27, 2015 ... and will have an update shortly.With a unique version number, Please. Link to comment Share on other sites More sharing options...
WilliamDavid Posted September 27, 2015 Author Share Posted September 27, 2015 Thank you HRS. I thought I was going mad. Link to comment Share on other sites More sharing options...
WilliamDavid Posted October 7, 2015 Author Share Posted October 7, 2015 I have re-downloaded Railmaster from above, and am pleased to see the function has been fixed. Also the short circuit function has been fixed.However, a communication from support would have been welcome, as I only re-downloaded because of a suggestion on this site.Anyway, well done HRMS. Link to comment Share on other sites More sharing options...
