drew_norris Posted September 30, 2015 Share Posted September 30, 2015 I was running my new DCC fitted class 08 shunter it stopped dead on the tracks it has only been used about 4 times it wasn't pulling any wagons and a pendolinono was running at the same time, I tried it again it is not responding to my controller which is a select the pendolino is still fine and my flying Scotsman run fine as well so I know its not a controller issue could it be the decoder or the motor it's only new so can't figure why it stopped Link to comment Share on other sites More sharing options...
Fishmanoz Posted September 30, 2015 Share Posted September 30, 2015 Hi drew, welcome to the forums. Not much info to help us here, but could you confirm the addresses you have allocated to your locos. If you have changed all from the default 03, as you should, can you try to see if the shunter responds on 03. Failing that, remove the Pendolino and FS from the track and try to reprogram the address of the shunter and see if it works on this new address. Link to comment Share on other sites More sharing options...
2e0dtoeric Posted September 30, 2015 Share Posted September 30, 2015 As it is new, take/send it back to where you got it from, before fiddling around inside! Get them to test it, and probably replace it. Link to comment Share on other sites More sharing options...
drew_norris Posted October 14, 2015 Author Share Posted October 14, 2015 Hi drew, welcome to the forums. Not much info to help us here, but could you confirm the addresses you have allocated to your locos. If you have changed all from the default 03, as you should, can you try to see if the shunter responds on 03. Failing that, remove the Pendolino and FS from the track and try to reprogram the address of the shunter and see if it works on this new address. Link to comment Share on other sites More sharing options...
drew_norris Posted October 14, 2015 Author Share Posted October 14, 2015 Good news I reprogrammed the loco with a new address it now runsthanks for your help Link to comment Share on other sites More sharing options...
