Yelrow Posted September 30, 2015 Share Posted September 30, 2015 greetings, My Schematic is set at 75%, where it fills my monitor. Its perfect. Every time i click on my tts sound functions, it flashes, eg, the little box showing 75%. Gets on your nerves. Has anybody else experienced this. HRMS, what gives. john Link to comment Share on other sites More sharing options...
RDS Posted September 30, 2015 Share Posted September 30, 2015 Hi JohnI realise it is different but did you see my thread last week titled: 'v1.62 - Track Layout Flashes 1st time points are operated'.This was cured when PJ suggested that Points need to be set at RailMaster start up. I ticked the relevant box, even though I don't have any individual points selected to set and the problem went away.I wonder if there is something similar affecting your display, I can't imagine what though! Link to comment Share on other sites More sharing options...
Fishmanoz Posted September 30, 2015 Share Posted September 30, 2015 Maybe it's the same not similar. Are you set up to set points on startup John? If not, try setting it. Link to comment Share on other sites More sharing options...
Yelrow Posted September 30, 2015 Author Share Posted September 30, 2015 Always had points clicking on start up, but turned them off. Makes No difference to the box flashing, either way. This did not happen before 1.62, or i would have noticed it. Think its another quirk for HRMS. Has nobody else noticed, or does nobody run at 75%. Track layout does not flash. Its only when you click on sound on/ horn/ any function on any loco. john Link to comment Share on other sites More sharing options...
Yelrow Posted September 30, 2015 Author Share Posted September 30, 2015 On another post, i pointed out i had no cog on bottom of screen in RM, to get to ini file. You can see why i dont want to risk another update. john Link to comment Share on other sites More sharing options...
Fishmanoz Posted September 30, 2015 Share Posted September 30, 2015 So download the latest 1.62 from the link at the top of the RM forum and see if that fixes it. You can't claim it ain't broke this time, you just described the brokenness. Link to comment Share on other sites More sharing options...
96RAF Posted September 30, 2015 Share Posted September 30, 2015 I found (and reported) that if you don't 'set points at startup' then the blue lines didn't appear on plan (even after clicking a point) and so far HRMS hasn't come up with a fix for it.@HRMS - can we please have a proper version/revision increment methodology as people are getting in a right muddle the way it is at present. Link to comment Share on other sites More sharing options...
Yelrow Posted September 30, 2015 Author Share Posted September 30, 2015 Fishy, i have been through this with RAF. There are so many little glitches with latest download, eg short circuit etc, i am staying with version i have, until all probs sorted. It would appear from my new Glitch, on old 1.62, that these probs also need sorting. john Link to comment Share on other sites More sharing options...
96RAF Posted September 30, 2015 Share Posted September 30, 2015 V1.62 Rev unknown - its a bit like income tax John the longer you avoid it the worse it gets... Link to comment Share on other sites More sharing options...
Yelrow Posted September 30, 2015 Author Share Posted September 30, 2015 I really think we are due a response from HRMS, surely things should not flash like this. john Link to comment Share on other sites More sharing options...
tony_forward Posted September 30, 2015 Share Posted September 30, 2015 Link to comment Share on other sites More sharing options...
tony_forward Posted September 30, 2015 Share Posted September 30, 2015 Reading all the complaints about 1.62, I think I'll wait for a while before updating, especially as my version and pc have been working well at exhibitions! Link to comment Share on other sites More sharing options...
Graskie Posted September 30, 2015 Share Posted September 30, 2015 V1.62 Rev unknown - its a bit like income tax John the longer you avoid it the worse it gets... I find the same with my missus, RAF. Link to comment Share on other sites More sharing options...
RDS Posted September 30, 2015 Share Posted September 30, 2015 ... then the blue lines didn't appear on plan ...I didn't know that was an issue. (The lines display OK on mine) Link to comment Share on other sites More sharing options...
96RAF Posted October 1, 2015 Share Posted October 1, 2015 ... then the blue lines didn't appear on plan ...I didn't know that was an issue. (The lines display OK on mine) Mine display only if I accept the set points option at startup, else not. Link to comment Share on other sites More sharing options...
