TOK774 Posted October 1, 2015 Share Posted October 1, 2015 I have a NSE 4 VEP class 423/1 bought from a model shop online, it says dcc fitted with standard hornby R8249 decoder, the train is hornby R2947. Which I'm trying to control with railmaster. The paper with the train says function 0- exterior directional lighting, function 1- interior roof lighting. in loco set up railmaster has this product and the functions are correct but nothing works, all lights come on, can not turn them off, the train doesn't move at all. I've run veriuos searches about he decoder and not found anything useful. Though I think the problem is railmaster but I'm unsure how to proceed. any advice would be appreciated Link to comment Share on other sites More sharing options...
Icurus Posted October 1, 2015 Share Posted October 1, 2015 HiHave you tried re-setting the decoders id? They come set as 03 from the factory usually. Link to comment Share on other sites More sharing options...
TOK774 Posted October 1, 2015 Author Share Posted October 1, 2015 Hi, yea I new that so I set it up on 3 the very first time. Link to comment Share on other sites More sharing options...
WilliamDavid Posted October 1, 2015 Share Posted October 1, 2015 Have you tried setting the loco manually, ie setting f0 and f1 yourself, with the descriptions direct. lights on/off, int. lights on/off?As for not running, this seems like a duff decoder.Are you using the Elite or Elink? Link to comment Share on other sites More sharing options...
Fishmanoz Posted October 1, 2015 Share Posted October 1, 2015 Not sure how rewriting the descriptions for F0 and F1 is going to help as the function wires will still be connected to the same lights. But TOK, ensuring the description in the setup includes on/off is useful to make sure the functions toggle - ie press once for on and a second time for off. Beyond that, I think we need more info to know what your problem might be. For a start, is your RM all properly set up and operating and able to control other locos and their functions, so this is the only one not working? If so, it could be a decoder problem. If not, it might be an RM problem. Let us know. Link to comment Share on other sites More sharing options...
TOK774 Posted October 5, 2015 Author Share Posted October 5, 2015 hallo, i do have elink, not elite. at the moment it was just a quick setup to test it all out see if it runs properly. I want to use DCC properly in the futue but i got to convert my other loco's to DCC. I really just wanted to see if it all worked.as far as i can tell being as eveything is new. either there is an issue with the decoder or the software on the computer. Edit: If the decoder is 003 as defult and asuming it is working fine then i need will to contact railmaster customer support. Link to comment Share on other sites More sharing options...
