DMU mad Posted October 18, 2011 Share Posted October 18, 2011 Hi,I have just bought a DCC ready bachmann class 66 and a Hornby 8 pin decoder, but need some help fitting the decoder. A step by step guide would be good help, but anything will be helpful.Thanks Link to comment Share on other sites More sharing options...
Southernman777 Posted October 21, 2011 Share Posted October 21, 2011 Hi,Hornby, Bachmann & others normally supply instructions with their locomotives showing how to fit a decoder when the loco is DCC Ready. The 8 pin plug should fit as it's a standard item not like car spark plugs. Just make sure the no 1 pin goes into the no 1 socket etc and that the decoder does not contact any metal chassis parts which will cause a short and maybe damage to the decoder.If the locomotive has a 21 pin socket you will need a 21 pin to 8 pin harness which is available from your local model shop.There is a good web site that gives details (step by step) of decoder fitting & programming on Broomgove Models. This web site has been given before on the Hornby Forum but Google or similar should locate it for you.I hope this helps, best regards, Link to comment Share on other sites More sharing options...
