mrcrazy504 Posted October 11, 2015 Share Posted October 11, 2015 windows 10 on my pc like the laptop but when i load the pc railmaster some times it works then i cloes it and reopen then wont there is power to the track but on load it wont cannot all the time but the laptop it work no probs and that got windows 10 Link to comment Share on other sites More sharing options...
Fishmanoz Posted October 11, 2015 Share Posted October 11, 2015 MRC, in the RM forum there are now many threads telling you how to go about fixing this. Suggest you take a look at some of the later threads there. Only a few on this General forum will know what you are talking about, and will care less. However, to summarise for you, first download and install the the latest version 1.62 from the link the top of the RM forum, then find a thread that tells you about the 2 extra lines that must go in the railmaster.ini file using the cog wheel facility in the RM Help window to do so. Reference to this can be found in multiple threads. Link to comment Share on other sites More sharing options...
RDS Posted October 11, 2015 Share Posted October 11, 2015 Just to be clear mrcrazy504, when Fishy says the RM forum, he is referring to the RailMaster section of this Hornby forum. Let us know how you get on. Link to comment Share on other sites More sharing options...
Yelrow Posted October 11, 2015 Share Posted October 11, 2015 Mr crazy, i am not a bit surprised you are confused, join the queue. I am afraid you will have to do a little reading of all the posts under 1.62, as both RDS, and Fishy say. And at the end of that, you will find there are 2 versions of 1.62, both with the same number. Once you have understood that, you then have to go into the INI file, and follow instructions, you have read. I am only repeating this , as it does belive me , seem crazy and confusing, but it has to do with the release of windows 10, and the solution found to the connection problems, by HRMS, who went to great lengths to solve the conflict. At the end of it all, everything works fine. Good luck, with reading the Necessary threads. It might help, to print out the relevant sections. john Link to comment Share on other sites More sharing options...
