mrcrazy504 Posted October 11, 2015 Share Posted October 11, 2015 i tryed every think i see on the forum plus i emailed them to but it still dos not work my elink work fine befor so im all upto date with railmaster i just dont no all i get is cannot communicate dcc controller com port 3 and thay both 115200 Link to comment Share on other sites More sharing options...
Chrissaf Posted October 11, 2015 Share Posted October 11, 2015 Have you modified your .INI file as documented on previous forum threads on this topic. You need to do this .INI file modification AS WELL as downloading and installing the VERY LATEST Railmaster from the link located at the top of this section of the forum..This is the reason that HRMS have added a 'COG' clickable icon in the Help Window of the latest RM version to make modifying the .INI file easier. Link to comment Share on other sites More sharing options...
geochoice Posted October 11, 2015 Share Posted October 11, 2015 Exactly Chrissaf, not one tiny issue but a combination of small changes that prevents the usb communication linking. Link to comment Share on other sites More sharing options...
mrcrazy504 Posted October 11, 2015 Author Share Posted October 11, 2015 try to ware is this cog in the help bit plus what files do i need adding again Link to comment Share on other sites More sharing options...
Fishmanoz Posted October 11, 2015 Share Posted October 11, 2015 Mr C, have you downloaded and installed the latest version from the link at the top of the RM forum? You must use this link to get the latest. You'll know once you've installed it as you will see the cog wheel in the Help window. You have told us you have Com3 and 115,200 in Setup but have you gone into Wndows Device Manager to check that it is set to these values too? These two must match. Link to comment Share on other sites More sharing options...
Fishmanoz Posted October 11, 2015 Share Posted October 11, 2015 In addition to my last, you finally have to use the cog wheel to edit your Railmaster.ini file and ensure it contains these 2 lines: Check controller=1 andAlternative comms=1 Make sure you type these exactly and don't include any extra spaces. If you have done everything in my last 2 posts and it is still not working, then email HRMS from within the Help window of RM and report what you have done and what problems you are still having. Link to comment Share on other sites More sharing options...
HornbyRailMasterSupport Posted October 12, 2015 Share Posted October 12, 2015 "mrcrazy" As you are aware, we have provided step-by-step help through emails over the last few weeks. Again, all you need to do it to click on the small cog symbol in the Help/About screen to edit the RailMaster.ini settings. If you do not see this cog simply download and install the latest version of RailMaster from www.powerpos.com/rail-master/rm_setup.exe over your existing one. Add the lines "Check controller=1" and "Alternative comms=1" on two separate lines in the RailMaster.ini file (without the quotes) and press the green tick to save it. Then restart RailMaster and ensure you have set the correct Com port number and BAUD rate in both RailMaster's settings and the Windows Device Manager (under LPT and Com heading). That is all you need to do and you should find that everything is fine. Link to comment Share on other sites More sharing options...
