choo choo1707821159 Posted October 24, 2015 Share Posted October 24, 2015 Hi All,just getting started back into the hobby after a few years of a break. Just wondering, i have the smokey joe and want to dcc it.which decoder would be best as i dont understand the differences between these two, R8249 Locomotive Decoder or R8245 Sapphire Decoder. Not looking to run lights or sounds, just run the train. Thanks guys. shane Link to comment Share on other sites More sharing options...
Augustus Caesar Posted October 24, 2015 Share Posted October 24, 2015 As magfan says the 8249 will suit. It's half the price of the 8245 and has less capabilities than the former. Check this link on Hornby's own site and click each decoder for a description.... https://www.hornby.com/uk-en/shop/power-control/dcc-decoders.html (copy and paste coz the tablet I am using can't add the link - duh) Link to comment Share on other sites More sharing options...
RDS Posted October 26, 2015 Share Posted October 26, 2015 ... i have the smokey joe and want to dcc it ... I have the Smokey Joe and I fitted an R8249 to it and it works well. Link to comment Share on other sites More sharing options...
choo choo1707821159 Posted November 2, 2015 Author Share Posted November 2, 2015 Thanks a million guys, Will be buying one soon. Link to comment Share on other sites More sharing options...
96RAF Posted November 2, 2015 Share Posted November 2, 2015 Squeezing a Sapphire in there will be a struggle. The basic decoder will fit and be up to the job.Have you seen the Hornby 0-4-0 decoder installation guide on this site? Link to comment Share on other sites More sharing options...
Fishmanoz Posted November 2, 2015 Share Posted November 2, 2015 I've seen the 0-4-0 guide and I've been pointing out for literally years that it's wrong. It shows as really complicated as you have to remove the motor as it is mounted with its connectors down. In fact in the last couple of years, the motor is mounted with connectors up so doesn't have to be removed. All you have to do is unsolder everything from motor connectors and throw away all suppression components, capacitors and inductors. Now solder pickup wires from each side to decoder red and black and decoder orange and grey to motor connections. Put body back, it's done! Link to comment Share on other sites More sharing options...
Wobblinwheel Posted November 3, 2015 Share Posted November 3, 2015 You may want to look at some inexpensive [other brand, American] decoders, particularly those for N scale, for size reasons. The R8249 has no "speed matching" CV's, if you ever might be interested in doubleheading with another loco. Even one of the cheapest ($18.00 American, around 13 GBP) has start voltage (CV2), max speed (CV5), and mid speed (CV6). This allows almost total control of how engine responds to the throttle settings. This same [other brand-American made] decoder also offers the F6 function which switches to "shunting mode", which cuts loco speed in half for precise slow-speed running (also, almost like a "brake" to slow engine rapidly). F6 also disables accel and decel settings for switching. Much more "bang for the buck" if these features interest you. Can I say the name on here? Of course, if you're not interested in these features, the 8249 works just fine..... Link to comment Share on other sites More sharing options...
Fishmanoz Posted November 3, 2015 Share Posted November 3, 2015 Yes Wobbly, you can tell us the brand. Link to comment Share on other sites More sharing options...
Howbi Posted November 3, 2015 Share Posted November 3, 2015 @ Wobblin............why not consider the Hattons MD4 decoder, £10. Has 4 functions, rated at 1.1 amp, addresses all the CV's you mentioned, back EMF and meets full NMRA DCC specs and size is only..18.5mm x 10.5mm x 4.8mm. A very usefull option. HB. Link to comment Share on other sites More sharing options...
Wobblinwheel Posted November 3, 2015 Share Posted November 3, 2015 Yes Wobbly, you can tell us the brand. Digitrax, cost me around 11.70 GBP, plus shipping. Link to comment Share on other sites More sharing options...
Wobblinwheel Posted November 3, 2015 Share Posted November 3, 2015 @ Wobblin............why not consider the Hattons MD4 decoder, £10. Has 4 functions, rated at 1.1 amp, addresses all the CV's you mentioned, back EMF and meets full NMRA DCC specs and size is only..18.5mm x 10.5mm x 4.8mm. A very usefull option. HB.Thanks, didn't know about that one. I, being in the US, buy a lot of Digitrax. Heck of a decoder for the money. I'm sure there's a good possibility that Digitrax makes the one for Hattons. Especially if the functions are identical. I have one loco with the R8249 in it. Works great, but I can't doublehead it with anything else I have, due to it's limitations. Loco doesn't even hardly move until speed step 15, while all my others are programmed to begin to creep at speed step ONE. Link to comment Share on other sites More sharing options...
