olly Posted October 22, 2011 Share Posted October 22, 2011 Can you use the hornby R8216 point decoders with a Gaugemaster prodigy advance DCC controller are they compatible? if they are how do you program them ? Link to comment Share on other sites More sharing options...
Flashbang Posted October 22, 2011 Share Posted October 22, 2011 HiYes it should be OK. However, the R8216 has some problems with programming, especially the Hornby Select, but it should be ok with the PA2.Please see the PA2 manual Page No 17 Item 2:11 which explains how to program a Accessory Decoder. I would personally connect the R8216 to the rails or DCC bus pair of wires (if you use a Bus pair) and power up the PA2. Leave the R8216 connected for around 60 second then move its input wires to the Programming track and programme as per the manual. Connecting the R8216 to the rails or Bus initially will allow the internal capacitors to reach a fully charge state. Link to comment Share on other sites More sharing options...
olly Posted October 23, 2011 Author Share Posted October 23, 2011 Flashbang said:HiYes it should be OK. However, the R8216 has some problems with programming, especially the Hornby Select, but it should be ok with the PA2.Please see the PA2 manual Page No 17 Item 2:11 which explains how to program a Accessory Decoder. I would personally connect the R8216 to the rails or DCC bus pair of wires (if you use a Bus pair) and power up the PA2. Leave the R8216 connected for around 60 second then move its input wires to the Programming track and programme as per the manual. Connecting the R8216 to the rails or Bus initially will allow the internal capacitors to reach a fully charge state. Link to comment Share on other sites More sharing options...
olly Posted October 23, 2011 Author Share Posted October 23, 2011 Thanks Flashbang I now have the point decoders working like you said the R8216 has some problems with programming . It needed at least a minute or so before it would work .Thanks very much for your helpolly Link to comment Share on other sites More sharing options...
