Gearoid Posted October 31, 2015 Share Posted October 31, 2015 Hi Folks,how can I program my new Murphy Model 071 in Railmaster? Link to comment Share on other sites More sharing options...
Fishmanoz Posted October 31, 2015 Share Posted October 31, 2015 Does it have a DCC decoder fitted? Assuming a decoder is fitted, then you program it like any other loco. There is an entire chapter on it in the manul starting at page 34. If you have read this and have a particular problem somewhere, give us some more detail and we can give specific help. Then there is also coverage of loco programming via the 2 locked threads at the top of the RM forum. Link to comment Share on other sites More sharing options...
Gearoid Posted November 1, 2015 Author Share Posted November 1, 2015 Thanks Fishman, I shoud have been more specific. I have been able to program the Murphy Models in the Railmaster Locomotive Setup function howver I had to base the Description/Icon on an existing Hornby diesel model.In the Railmaster.ini file the following setting can be found: Load Hornby locos =1The following can also be added to include other manufacturers:Load Rivarossi locos =1 Load Jouef locos=1 Load Arnold locos=1 Load Electrotren locos=1But no such option is available for Bachmann, who currently manufacture Murphy Models. Murphy Models cover all of the Irish Locomotive stock from the 1950's to the present day and it would be nice to include them in Railmaster loco Setup. Or maybe it is possible using another method? Link to comment Share on other sites More sharing options...
Yelrow Posted November 1, 2015 Share Posted November 1, 2015 I had to do same with my ftateschi turntable eg 022. Hornby show only their companies. After all, it is a hornby product, Bachmann, being their main competitor. john Link to comment Share on other sites More sharing options...
Fishmanoz Posted November 1, 2015 Share Posted November 1, 2015 All the brands you've mentioned are owned by Hornby gearoid, hence being able to call them up in RM. There is no such option for non-Hornby and the way you have done it is the only way. This is not the case for decoders though and RM recognises just about all of the more popular decoder brands, both loco and accessory. Link to comment Share on other sites More sharing options...
Gearoid Posted November 1, 2015 Author Share Posted November 1, 2015 Thanks John, that explains it ............ Link to comment Share on other sites More sharing options...
Gearoid Posted November 1, 2015 Author Share Posted November 1, 2015 Thanks Fishman ...... Link to comment Share on other sites More sharing options...
96RAF Posted November 1, 2015 Share Posted November 1, 2015 If it is a sound model then you can cycle through the function listings to pull up Hornby or Bacchman steam and diesel sounds, but if these don't suit yoru function listing then all you do is overtype the necessary description in by hand to match your decoder's listing. If not a sound model then again just type in your parameters like cruise and shunt speeds, description, etc. Link to comment Share on other sites More sharing options...
Gearoid Posted November 9, 2015 Author Share Posted November 9, 2015 Thanks RAF96,Yes I tried editing the function buttons for the loco and that works fine. The 071 has two additional High Beams (Under the drivers window), that can be activated by pressing the Coach Lights buttton. If I edit the text on this button to lets say 'High Beam', the functionality changes . Now if I press the 'High Beam' buttom the lights will come on, but, will only stay on for a few seconds. Whereas if I dont edit the text on the button, the lights will stay on until I hit the button to switch them off. Its just a minor issue, Just wondering if there is any way around it ? Link to comment Share on other sites More sharing options...
Fishmanoz Posted November 9, 2015 Share Posted November 9, 2015 Sounds like you've edited out the words on/off when making the changes. Add on/off as this makes it a latching function that stays on until you press it again. Link to comment Share on other sites More sharing options...
Gearoid Posted November 10, 2015 Author Share Posted November 10, 2015 Thanks Fishman ......... Link to comment Share on other sites More sharing options...
