NormanQ4 Posted December 10, 2015 Author Share Posted December 10, 2015 Thanks HRMS, resetting the factory settings etc. did the trick.A simple solution to an annoying problem, and a lesson learnt .And thanks again to those of you who assisted me with head scratching, it was very much appreciated. Link to comment Share on other sites More sharing options...
Fishmanoz Posted December 10, 2015 Share Posted December 10, 2015 You might like to check your CV29 now Norman. It is probably 6, giving you 128 speed steps and DC running on. Previously your value of 20 had 28 speed steps and complex speed curve. If you never use your locos on DC, better to turn DC Running off. Link to comment Share on other sites More sharing options...
NormanQ4 Posted December 11, 2015 Author Share Posted December 11, 2015 Hi RayNo I didn't do that since HRMS seems to have solved the problem for me. Link to comment Share on other sites More sharing options...
NormanQ4 Posted December 11, 2015 Author Share Posted December 11, 2015 You might like to check your CV29 now Norman. It is probably 6, giving you 128 speed steps and DC running on. Previously your value of 20 had 28 speed steps and complex speed curve. If you never use your locos on DC, better to turn DC Running off.Hi FishyCV29 on one loco is now reading 000 and "Allow DC operation" is off.CV29 on other loco is now reading 002 and "Allow DC operation" was on but I turned it off. Link to comment Share on other sites More sharing options...
HornbyRailMasterSupport Posted December 11, 2015 Share Posted December 11, 2015 Remember that the loco decoder, like accessory decoders and even some colour light signals are miniature computers. They have a CPU, ROM, RAM and so on. Sometimes, they do wierd things and the only thing for it is to reset them to factory settings. Link to comment Share on other sites More sharing options...
RDS Posted December 11, 2015 Share Posted December 11, 2015 Thanks HRMS, resetting the factory settings etc. did the trick ... ... Hi RDS, I've even tried that old chestnut ... Ah, another old chestnut!!! Link to comment Share on other sites More sharing options...
NormanQ4 Posted December 11, 2015 Author Share Posted December 11, 2015 Thanks HRMS, resetting the factory settings etc. did the trick ... ... Hi RDS, I've even tried that old chestnut ... Ah, another old chestnut!!!Looks like everyone's playing conkers! Link to comment Share on other sites More sharing options...
Tee1707818014 Posted December 11, 2015 Share Posted December 11, 2015 Glad you got it sorted Link to comment Share on other sites More sharing options...
NormanQ4 Posted December 12, 2015 Author Share Posted December 12, 2015 at least it is fixed and you are playing trains again.did anything weird ,ie a short/ derailment,happen before the loco's went bonkers needing conkersSimply switched RM from an old XP PC to a new Win 10 PC. Link to comment Share on other sites More sharing options...
Fozzy Bear Posted December 31, 2015 Share Posted December 31, 2015 I have experienced a similar funkiness and found that "pushing" the slider up was the problem. It seemed to "stick" to the mouse cursor and moved up and down even when the cursor was away from the slider with no mouse buttons pressed. I now click on the area above the slider where I want it to go to and it steps up to the required position by itself. This has its own problems in that the engine will go very slow. For example, if I click to 100kmh, the slider moves up but the engine will go at maybe 30. If I click on the cruise which would be set to 100, the engine resumes the correct speed. This is slightly annoying but at least all the stop buttons work correctly. Link to comment Share on other sites More sharing options...
HornbyRailMasterSupport Posted December 31, 2015 Share Posted December 31, 2015 If you mouse cursor is "sticking" to the slider this indicates a problem in Windows rather than RailMaster.You might want to have a look at your mouse settings in control panel and turn off the function that automatically snaps it to a field or control. You should also turn off any fancy mouse control functions that you do not use (especially if using a touchpad). Link to comment Share on other sites More sharing options...
