Pangaea Posted December 15, 2015 Share Posted December 15, 2015 I have an R2949 HST that's been sitting around brand new for a while, so today I decided to open it up and place it on my DCC layout for a run. At first, the train did not move at all, and when I got it to move, it moved for 2 seconds, stopped for 3 seconds, moved for 2 seconds, stopped for 3 seconds, etc.Every other DCC loco worked fine, so I presumed that the controller (Elite) and the track wasn't at fault.On another note, is vibration and a loud buzzing noise normal on DC layouts using the R8250 controller? Link to comment Share on other sites More sharing options...
Fishmanoz Posted December 15, 2015 Share Posted December 15, 2015 Welcome to the forums Pangaea. On the HST part of your question, if a Hornby DCC fitted model, it would be R2949X, and there doesn't appear to be any such model. So if DCC fitted, it must have been done after market, so not brand new. What ID number are you running it on? And a note - if DCC Ready and not DCC fitted, that means it is DC with a socket for a decoder with a blanking plug in it. While DC works on a DCC layout, you shouldn't do it as you run a real risk of burning out the motor. Finally, if you are sure it's DCC, have you tired leaving it stop/starting for a while to see if it improves with running in? Link to comment Share on other sites More sharing options...
Rog RJ Posted December 15, 2015 Share Posted December 15, 2015 It was available DCC fitted. See http://www.ehattons.com/32166/Hornby_R2949X_Class_43_HST_power_43321_and_dummy_43285_pack_in_Arriva_Cross_Country_livery_DCC/StockDetail.aspx You haven't screwed the transit bracket screws back in, have you? They should be removed. Link to comment Share on other sites More sharing options...
Fishmanoz Posted December 15, 2015 Share Posted December 15, 2015 Thanks Rog, all I looked at was this site, where it no longer appears at all, and the Hornby Railways Collector Guide which has 2949 but not 2949X. Link to comment Share on other sites More sharing options...
