Duke748 Posted December 19, 2015 Share Posted December 19, 2015 HiI’ve just installed a new decoder (R8249 4 Function) to my DCC Ready Hornby Pendolino. I’m running RailMaster Pro through an eLink box. I managed to programme the loco’s DCC ID & having read the “Loss of Functionality” forum thread I double checked CV29 which seems to be set up correctly (Decimal Value 6 with 28/128 speed steps & DC operation enabled). The problem I’m having is that none of the lights on the drive unit at the front of the train come on but the dummy power car at the back of the train has both the white & red lights permanently on. When I run the train on DC, the lights work fine with white at the front & red at the back in both directions. Movement-wise, the train works fine in both directions under RailMaster control. Ditto when moving forwards under analogue DC but it’s very stop/start in reverse under analogue control since I fitted the decoder chip. The same thing occurs with the 0-6-0 loco I have (Hornby factory fitted decoder), it goes forwards OK but keeps stopping & starting in reverse through the analogue controller. I guess it’s not a big deal as the train seems to run correctly but I’m wondering if I’ve done something wrong?Many thanks Link to comment Share on other sites More sharing options...
Duke748 Posted December 19, 2015 Author Share Posted December 19, 2015 Thanks, that explains a lot. I'd assumed that I only needed one decoder in the drive car. I don't recall doing the function 0 thing either. I'll sort this out & hopefully it'll resolve the problem. Appreciate your help. Link to comment Share on other sites More sharing options...
96RAF Posted December 19, 2015 Share Posted December 19, 2015 @ dukeWhat you have described - no lights at the front and all lights at the rear is exactly what you will get with a decoder in the front car and F0 off and no decoder in the rear car. Link to comment Share on other sites More sharing options...
Duke748 Posted December 21, 2015 Author Share Posted December 21, 2015 Thanks everyone, it's all sorted now :-) Link to comment Share on other sites More sharing options...
96RAF Posted December 21, 2015 Share Posted December 21, 2015 Thanks for reporting back duke - not everyone does so we are often left hanging, never sure if the problem was solved or the poster lost interest.good luck with running your trains... Link to comment Share on other sites More sharing options...
