graham the train Posted December 22, 2015 Share Posted December 22, 2015 why has my type 47 tts sound train dont want to play after having lights fitted by an a professional, and also it does state in the manual that this is possiable. Link to comment Share on other sites More sharing options...
Fishmanoz Posted December 22, 2015 Share Posted December 22, 2015 Very little to go on there Graham. For a start, are sounds turned on? Your fitter may well have found them annoying and turned them off. Oh and Adam, can you please give this thread a reasonable title like Class 47 TTS Sounds Not Working for graham. Link to comment Share on other sites More sharing options...
Yelrow Posted December 22, 2015 Share Posted December 22, 2015 Hi, i would be asking that question to the professional that disturbed the sound decoder. john Link to comment Share on other sites More sharing options...
2e0dtoeric Posted December 22, 2015 Share Posted December 22, 2015 Also - what controller are you using? It has been said before that TTS doesn't always work with 'foreign' controllers.Also -(another also) - what code has the loco been set to, and are you using the correct one from the controller? Link to comment Share on other sites More sharing options...
RDS Posted December 22, 2015 Share Posted December 22, 2015 From the title, I thought it was a new addition to the Thomas the Tank engine range Link to comment Share on other sites More sharing options...
Fozzy Bear Posted December 26, 2015 Share Posted December 26, 2015 I have the same loco and it is one of the best. Runs flawlessly and can pull a looong rake...until it died. After my initial horror, I pulled it apart and found one of the wires to the motor had snapped off , just from the twisting movement of the drive bogie ( I guess) . The wire is very hard to see and even harder to repair so it would not surprise me if yours has done the same when old mate was fitting the lights.Does the sound still work? Link to comment Share on other sites More sharing options...
