Chalky1707817905 Posted December 27, 2015 Share Posted December 27, 2015 Is it possible to use track plans created with scarm or other computer programs with RM Pro using current version Link to comment Share on other sites More sharing options...
Fishmanoz Posted December 27, 2015 Share Posted December 27, 2015 If you mean can they be used as schematic layouts in RM, the answer is no. It really wouldn't save all that much as it is quite simple to create a schematic of your actual or designed layout. Link to comment Share on other sites More sharing options...
ModelerXYZ Posted January 1, 2016 Share Posted January 1, 2016 RM plans are schematics. Track master/scarm plans are drawings. rm plans are not true to life,m TM plans are. xyz Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 1, 2016 Share Posted January 1, 2016 Quite right XYZ. I assumed Chalky understood that and was asking if a real one can be imported to RM to make an RM schematic. At least that was the basis for my answer of no. Link to comment Share on other sites More sharing options...
96RAF Posted January 2, 2016 Share Posted January 2, 2016 I suggested this a while back and the coders said it was too difficult to transcribe a track plan (actual parts) to a screen plan (schematic) or vice versa. SCARM also has the facility to draw up a schematic using 'noddy' lines in lieu of track parts, so it could be used to help draw an RM one. Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 2, 2016 Share Posted January 2, 2016 RAF, I assume you mean make the schematic with SCARM then use it to help you make your RM schematic in layout design, not import it? Link to comment Share on other sites More sharing options...
