Manston HELP!
Cackey
Just received my loooooooong awaited collectors club BoB model and desperately trying to separate the tender chassis from the body in order to fit decoder. Carefully following the instructions as per Fig's 8 & 9 of the supplied instruction sheet and cannot begin to disengage the 2 parts. Is their anybody out there who has succeeded?
Cackie
I managed it after a bit of a fight!
Undo the screws underneath and ease the rear of the tender body up. I had to slide a very thin blade between body and chassis to stop it snapping back into place but then I managed to in lip the front by pulling the whole body backwards - it gives up with a big click!
You will snap the steps off though - can't be avoided.
Many thanks to both Steve & Roy.
You are certainly correct in saying that the supplied instructions are wrong, as it is necessary to ease the tender body up from the rear (screw end) then pull back.
Once mastered I was able to fit the decoder, reassemble, programme and successfully run this lovely model in record time.
Thanks once again for your invaluable help.
Cackey
