MikeHorne Posted December 29, 2015 Share Posted December 29, 2015 here is RailModeller rendition of my 6yr olds track sketch, this is our first attempt at a board based track on 8x6 ply.we have a problem where we cant seem to connect the track by the software, i presume when the track is on the board we can jiggle and move the track into its correct allinment?/media/tinymce_upload/136932c900ad169f18af816fde332bc4.jpg Link to comment Share on other sites More sharing options...
Blagard Posted December 30, 2015 Share Posted December 30, 2015 No don't try and force it. It seems too far out for that. This is where the quarter and shorter straights come in handy. To align yours a few adjustments would be needed. C8200 & C8236 are 87mm and 78mm respectively and with that 9mm difference you will find inserting one of each in sections of track parrallel to each other (or just one) can close those smaller gaps. For example replacing the single full straight above the gap with a half and a perhaps a C8236 would close the horizontal gap without need for the red quarter straight. The the vertical alighnment needs to be adjusted in a similar way by having a short and a quarter inserted opersite each other to move one part vertically 9mm more than the other. It might then be close enough to close off. Link to comment Share on other sites More sharing options...
Maple Man Posted March 29, 2016 Share Posted March 29, 2016 Hey Mike Horne,Did you get the track layout to work? It is a nice layout for your first board based track on 8x6 ply. What does the numbers represent on your drawing?Thanks,Maple Man Link to comment Share on other sites More sharing options...
