john_snell Posted January 1, 2016 Share Posted January 1, 2016 I have a class 47tts running with elink and railmaster 1.63 revision 3. Its been working fine but now suddenly if I activate F1 to turn engine sound on it starts up but after a few seconds it shuts down ie no idle and no sound as it goes round the track. All other sound functions are working OK. Looked up fact sheet that came with loco read all about leaving thrashing left on etc. Changed loco address CV8 to 8 to reset defaults no go. As loco has two sound channels one seems to be working and one not. I therefore suspected the loco. In desparation I tried loco with my old select unit bingo everything worked fine. Problem is therefore not with the loco. Anybody any ideas? My only thought is to completely uninstall railmaster and start again with all the problems that brings. Link to comment Share on other sites More sharing options...
Chrissaf Posted January 1, 2016 Share Posted January 1, 2016 John, welcome to the forum with your 1st post..I wish I had £1 for everytime I provided this answer. The "F1 Sound" button label in Railmaster needs to have the text "on/off" included in the label name..To save me re-typing a whole answer, see this previous reply recently posted. In this case the function in question related to F0 'Lights' but it is the same for F1 'Sound' as well..EDIT: as magfan said. Don't uninstall RM. It isn't necessary, nearly every RM issue I have ever seen is usually a mis-configuration issue of some type. Link to comment Share on other sites More sharing options...
St1ngr4y Posted January 1, 2016 Share Posted January 1, 2016 If you open up the loco configuration screen for your loco, does the description for F1 contain the exact phrase "on/off". This is needed for a latching function as mentioned by magfan.Ray Ooops was typing at same time as Chris... Link to comment Share on other sites More sharing options...
john_snell Posted January 1, 2016 Author Share Posted January 1, 2016 Thanks guys. Everything seems to be working great now. Link to comment Share on other sites More sharing options...
