JohanC Posted January 5, 2016 Share Posted January 5, 2016 I have two Hornby DCC Fitted locos bought as part of a DCC set back in 2009. I have programmed them successfully with my Select controller. I have just upgraded to an Elite controller and tried to change their loco numbers but they just won't accept the change. Later locos accept the change without any problem.Is this a known problem? Is there a work around?Regards John. Link to comment Share on other sites More sharing options...
Rog RJ Posted January 5, 2016 Share Posted January 5, 2016 You could try a decoder reset which will/should return the decoders to the default address of 3. Writing 8 to CV8 is the reset procedure for Hornby chips. Link to comment Share on other sites More sharing options...
mjb1961 Posted January 5, 2016 Share Posted January 5, 2016 Could be the elite or the older style decoders ,I do know that the elite can be problematic when it comes to programming because the voltage from the programming outputs are quite low and the older decoders just may not be getting the command .i can only suggest installing a newer version decoder ,I say this about the elite because I had one and it just didn't want to programme I also googled the problem and it seemed to be a common problem ,sorry I can't be of any help,,,,,,,, Link to comment Share on other sites More sharing options...
JohanC Posted January 5, 2016 Author Share Posted January 5, 2016 Thanks for your comments. I think I will keep my Select for programming. I also have the eLink so I have options. Just a bit annoying.Thanks again.John Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 5, 2016 Share Posted January 5, 2016 No there shouldn't be an issue, although clearly there is. This is something I would cerrtainly be wanting t fix so I could use long IDs equating to the loco running number, and so be able to remember them more easily. Try programming with the Elite with only programming track connected, not layout, and see if that improves things. Link to comment Share on other sites More sharing options...
JohanC Posted January 6, 2016 Author Share Posted January 6, 2016 I tried it with just the programming track connected. No luck. But thanks anyway. Link to comment Share on other sites More sharing options...
Chrissaf Posted January 6, 2016 Share Posted January 6, 2016 Are you using the very latest version of Railmaster 1.63 revision 3 as downloaded from the top of the Railmaster section of the forum. Reason I ask, is that HRMS stated that this version contained some modifications to the way RM wrote and read CVs to Accessory Decoders to make reading and writing more reliable. It is possible that these mods, whatever they were, might have also improved loco reading and writing reliability too. Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 6, 2016 Share Posted January 6, 2016 No mention of his using RM at all Chris, just Select or Elite? I'm suspecting he has a close to original Mixed Freight set, the only set that long ago coming with 2 DCC Fitted locos, and that the 4-pin decoder fitted to them (can't remember it's X number off the top of my head) is an early version that may not be fully DCC compliant. If that's the case, he'll have to stick with the Select to program them, or replace them with the current model decoder. The part number is something like X8969 but wouldn't swear by it. Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 6, 2016 Share Posted January 6, 2016 Tried to find the correct number and failed, the one above is wrong. It also isn't X8659 which is a 4-pin decoder (for Sentinel etc) but not the direct plug type I mean. Someone will know? Link to comment Share on other sites More sharing options...
Howbi Posted January 6, 2016 Share Posted January 6, 2016 @fishmanoz...............I have a 5year old Mixed Freight set and have just changed each loco address with my Elite controller without any difficulty, so not a problem. HB. Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 6, 2016 Share Posted January 6, 2016 Hhmm, interesting HB. Doesn't help Johan though. Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 6, 2016 Share Posted January 6, 2016 Mixed Freight was first produced in 2010, so maybe my assumption that is what Johan is referring to from 2009 is wrong anyway. Will have to wait for him to come back, hopefully with R numbers, so we can check further for him. Link to comment Share on other sites More sharing options...
Chrissaf Posted January 7, 2016 Share Posted January 7, 2016 No mention of his using RM at all Chris, just Select or Elite?.Duh!!!.......that's rare for me not to read the OP post properly........must have read Elite and thought eLink..In that case, what firmware have you got on the Elite Johan, is it 1.41 or 1.42 the firmware version flashes up briefly on the Elite LCD screen during power up. Link to comment Share on other sites More sharing options...
Howbi Posted January 7, 2016 Share Posted January 7, 2016 @johan..........just a thought, Johan..........with the Elite, did you move the connecting lead from the Track sockets into the Program sockets at the rear and then back again after programming?...........Sorry if that sounds obvious but it's easily missed. HB. Link to comment Share on other sites More sharing options...
Chrissaf Posted January 7, 2016 Share Posted January 7, 2016 No mention of his using RM at all Chris, just Select or Elite?.Duh!!!.......that's rare for me not to read the OP post properly........must have read Elite and thought eLink..I thought there must have been a reason for me to mention RailMaster Fishy. On page 1, fourth post down Johan adds that he also has an eLink as well as his Select and Elite. So I then assumed that he could be still using RM but with the Elite instead. Link to comment Share on other sites More sharing options...
JohanC Posted January 7, 2016 Author Share Posted January 7, 2016 I have just succeeded in programming both the old locos using "Reg" mode rather than "Direct" mode on the Elite. No idea why this works but it does. Don't we just love computers!Thanks for all the comments.Regards, John Link to comment Share on other sites More sharing options...
JohanC Posted January 7, 2016 Author Share Posted January 7, 2016 The code for the Mixed Goods set is R1075 and was purchased on 28 Feb 2009. Firmware on the Elite is 1.42.Hope that helps. John Link to comment Share on other sites More sharing options...
Howbi Posted January 7, 2016 Share Posted January 7, 2016 @johan............nice one, John, for adding to our fount of knowledge............the Elite manual says that Register & Paged programming systems are best suited for the much older decoders............we live and learn.... HB Link to comment Share on other sites More sharing options...
