PJ_model_trains Posted January 14, 2016 Share Posted January 14, 2016 As for the turnouts, seems you have a bad case of amnesia! :) Again, a red signal does not mean a block is clear. When a train turns out there is no way to know the block ahead is clear or not. Seems you are not following this hosh, Red Block Clear where did that come from??? I appreciate sometimes explanations are hard to follow, the person writing always know what they mean, getting the message over without images isn't always easy, especially when talking, S this and P that T the other etc. I will try explain another way. _Clear?_[s4-Red]________<Train2______[s3-Red]__ (inner track) symbol shows branch _Clear?_[s2-Green]________<Train1____[s1-Red]__ (outer track) The Block Train2 is in (between S3-S4) is occupied but the signal ahead S4 is Red stopping the train continuing. The Block Train1 is in (between S1-S2) is occupied but the signal ahead is Green/Clear allowing Train1 to continue into next Clear Block. The Next Block Clear? could be straight ahead or Branch, that is defined by the points. As the points are to turn-off we know which Block is clear. Point define direction, signal confirms whether Block moving into is Clear or not. When Train1 passed S1 it changed signal at S3 Red, it then changed points for the turn-out to allow Train1 to branch onto inner track. The Block on the inner track is Clear, the signal at S2 confirms this, the signal at S4 protects it. Actions therefore were, Stop oncoming traffic on line crossing to, set conditions (change points), once safe to move into Clear Block change S2 Green. Link to comment Share on other sites More sharing options...
Slornie Posted January 14, 2016 Share Posted January 14, 2016 The Next Block Clear? could be straight ahead or Branch, that is defined by the points. As the points are to turn-off we know which Block is clear. Point define direction, signal confirms whether Block moving into is Clear or not.When Train1 passed S1 it changed signal at S3 Red, it then changed points for the turn-out to allow Train1 to branch onto inner track. The Block on the inner track is Clear, the signal at S2 confirms this, the signal at S4 protects it.Actions therefore were, Stop oncoming traffic on line crossing to, set conditions (change points), once safe to move into Clear Block change S2 Green. So presumably then there also needs to be some way to check the intended destination block is clear before the points are allowed to be set that way? For instance if in your example Train2 had already passed S4 and was in that leftmost block when Train1 reached S1, you wouldn't want the detection at S1 to change the points to let Train1 transit from outer to inner track because the destination block is potentially already occupied - Train2 could in fact still be running across the points at that very moment! Link to comment Share on other sites More sharing options...
PJ_model_trains Posted January 14, 2016 Share Posted January 14, 2016 @HRMS @Slornie Train1 triggered signal at S4 to Red when it was at S1, at which time Block S4 West was Clear. Train2 was in the Block S3-S4 so would approach the Red signal S4 and stop before it. If Train2 had passed S4 it would declare the Block S4 West occupied by the Red signal protecting it so wouldn't allow Train 1 to continue therefore wouldn't change the points. You have raised a good point, it is clear that RM with LD will have to remember some things but, also clear of the need that RM cannot change a Red signal a train/loco has passed making a next Block occupied, in this case RM trying to Set S4 Red and it is Red... so do nothing with this signal. IF Red - THEN Red - ELSE change as commanded. I think there is another issue here, not just the protected Blocks but not allowing points to change into a protected Block. Link to comment Share on other sites More sharing options...
hosh Posted January 14, 2016 Author Share Posted January 14, 2016 If Train2 had passed S4 it would declare the Block S4 West occupied by the Red signal protecting it so wouldn't allow Train 1 to continue therefore wouldn't change the points. This makes no sense. How does any of this give Train 1 any clue about anything? There are 2 proper solutions for this problem - Block occupancy knowledgeSignalling that can see backwards along any route, not just the mainline. There is another bodgey method - only allow train1 to proceed if the signal in the block ahead is non red. But it looks like RM cannot be used to command a loco at a sensor other than the one it's at so even this doesn't work. Link to comment Share on other sites More sharing options...
hosh Posted January 14, 2016 Author Share Posted January 14, 2016 I want to hear from someone with RM Pro, signals and what's on pages 82-84 of the pdf. It would seem that there would be sensor commands used to effect other sensors back down the line. If so, then all that's needed is to be able to do this for various point settings and then the signalling can be controlled back down any line, not just the mainline. So a sensor is triggered and the signalling is R(the signal at this sensor), R, Y, YY, G back down the line. This means that all blocks back from the front one are clear. This actually then becomes the same as block detection. But there is still a problem - what about when there is a train on the inner line that is between the blocks on either side of the points? It is not in the ahead block yet and so there is no signalling information available for that block yet. Looks like block detection will be required. Link to comment Share on other sites More sharing options...
Gregd99 Posted February 1, 2016 Share Posted February 1, 2016 @hoshIt is anything but "bog simple". 😢 The software needs to understand the topology of the network.... ie which bits of track are connected to which other bits. Note that this changes in time as turnouts/points are operated. Block A was connected to Block B.... but now is is Block C. Given the knowledge of the dynamic topology of the network routing and occupancy schemes can be developed. Signals can indicate the occupancy; Red=do not enter, Amber=slow down, next block is occupied. Then you need to think about block size... what if a block length is less than the length of a train? This is really interesting stuff but it does get a bit complex. The problems are not new and there is interesting reading available about railway signalling systems and the underlying issues that need to be managed. Do we know what RM is considereing? it might be as simple as "play an announcement" when detector X is active. Link to comment Share on other sites More sharing options...
hosh Posted February 1, 2016 Author Share Posted February 1, 2016 @hoshThe software needs to understand the topology of the network.... ie which bits of track are connected to which other bits. That's 100% correct but the problem is, from what we "know" about now, RM wont know this at all, thus all the confusing conversations that ultimately lead nowhere! :) I'm betting that when RM is released that a lot, if not all, of the stuff that we "know" about now will be gone. I think they realised how much it wasn't going to be able to do and have gone back to the drawing board. Programming instructions into every sensor for every train is an absurd approach imo. It creates no relative positions between sections and will be a nightmare to change individual trains to different scripts. Link to comment Share on other sites More sharing options...
