robert_jarrett Posted January 8, 2016 Share Posted January 8, 2016 I am using railmaster with elink on my.Vista laptop and been running it just over a year. I wanted to program an accessory decoder with different point nos. Using a programming trackon setting up I lost conyact with the elink controller I checked for thedriver port on device manager and it had disappeared and the elink just keeps flashing green Is there a problem with elink! Should I uninstall and start againI am using version 1.6 any suggestions Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 8, 2016 Share Posted January 8, 2016 Hi Robert, welcome to the forums. For a start, the very last thing you will need to do is uninstall and start again. However, the first thing you should do is download and update to the latest version via the link at the top of this RM forum. Just click on the link, then follow instructions to run and update. Let us know how you go and if that fixes it. Link to comment Share on other sites More sharing options...
robert_jarrett Posted January 9, 2016 Author Share Posted January 9, 2016 many thanks for the update advice, I have installed latest version but afraid it did not correct my problemwhich led me to change my 4amp power suply to the 1 amp and I have now got the elink backthis proves the the 4amp suply is caputthankyou fishmanoz Link to comment Share on other sites More sharing options...
96RAF Posted January 9, 2016 Share Posted January 9, 2016 Strange Robert that you think the 4A PSU is duff when you said you had a green flashing light on the eLink.Usually these things work or they dont - no in-between state.If you have a meter then could you please check the output voltage and report back. Link to comment Share on other sites More sharing options...
Yelrow Posted January 9, 2016 Share Posted January 9, 2016 I dont think its anything to do with 4 amp supply. If you re- connected it, and turned everything back on, it would i think be fine. Its all to do with the RM/ elink, connection, the wait, wait wait bit. Once you turn it on, wait for everything to stop flashing, all will be good?. john Link to comment Share on other sites More sharing options...
Chrissaf Posted January 9, 2016 Share Posted January 9, 2016 Robert, it sounds like you haven't got the extra two lines in your 'railmaster.ini' file that are recommended when using the 1.63 version of RM..Alternative comms & Check controller.See the fifth post down by HRMS in this previously posted thread..Review page 33 of your 1.63 user manual. The electronic pdf one that RM will have installed onto your desktop as part of the upgraded RM installation, not any previous printed copy. Since you are using Vista with eLink. I would think going by what is shown on page 33 that Alternative comms =0 and Check controller =1 will be the appropriate entries. If that doesn't work try Alternative comms =1 instead. See the middle section of page 33 to see how to access and edit your .INI file. Link to comment Share on other sites More sharing options...
robert_jarrett Posted January 9, 2016 Author Share Posted January 9, 2016 Thank you for your infomation you are quite right it is not the 4amp power as it works with my selectThe elink green light stays on with the1amp power plug cannot get any output power for my program trackI am coming to conclusion that that there is a fault with elinkI will try some of your suggestions first and will come backthanks again robert Link to comment Share on other sites More sharing options...
Rog RJ Posted January 9, 2016 Share Posted January 9, 2016 I'm pretty sure that there should be no power to the programming track until you are actually programming or reading a decoder. The programming track isn't supposed to be able to run locos. Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 9, 2016 Share Posted January 9, 2016 Have you followed Chris's advice above with his link to the HRMS post. That is definitely your next step, forget about power supplies for now, unlikely to be the cause. Link to comment Share on other sites More sharing options...
