Smithy58 Posted January 10, 2016 Share Posted January 10, 2016 i have just installed an Esau sound decoder in to an gauge HST, in the procees of trying to change the default cv from 3 to 11, I noticed the time to pause between readings seems to be defaulting to 4 s, has some update taken place As every time I change it to 15 s it keeps reverting back to 4 and is causing problems with trying to read the decoder values.thankns in advance for any help regards colin Link to comment Share on other sites More sharing options...
2e0dtoeric Posted January 10, 2016 Share Posted January 10, 2016 What controller are you using? Link to comment Share on other sites More sharing options...
Smithy58 Posted January 10, 2016 Author Share Posted January 10, 2016 What controller are you using?Railmaster / elink the decoder is a esu loksound microdecoder Link to comment Share on other sites More sharing options...
2e0dtoeric Posted January 10, 2016 Share Posted January 10, 2016 Ah, can't help with that one, sorry, I'm not using one, just an Elite. Link to comment Share on other sites More sharing options...
WilliamDavid Posted January 10, 2016 Share Posted January 10, 2016 I'm having no problems with mine.It is set at 12secs.Whatever value I set it at, 8, 15 it keeps.I am on latest versions of both.Send a query to Railmaster Support. Link to comment Share on other sites More sharing options...
Chrissaf Posted January 10, 2016 Share Posted January 10, 2016 Colin,.Whenever you get these kind of quirky odd things happening, I find the best thing to do is to over install your current installation with the very latest one downloaded from the link at the top of the forum Railmaster section. Currently showing 1.63 revision 4 - no need to uninstall current version first, just run the downloaded installer over the top of the installed version and the relevant files will be updated..There was a post recently where HRMS stated they had modified CV reading & writing for Accessory Decoders, this might have affected Loco decoder CV reading & writing too. In that post, they recommended downloading the latest version as I stated above..If that doesn't fix your issue, then report it to HRMS using the inbuilt support request feature located on the RM help page as WD suggested. HRMS will only come back and ask you to install the latest copy anyway, that always seems to be their stock initial response, so you might as well do it first to save time. Link to comment Share on other sites More sharing options...
Smithy58 Posted January 10, 2016 Author Share Posted January 10, 2016 Thanks will try this tomorrow regards exasperated Colin Link to comment Share on other sites More sharing options...
WilliamDavid Posted January 11, 2016 Share Posted January 11, 2016 I think I gave you the wrong answer.On my Win7 tablet, when connected to the elink, I get exactly what you say, it defaults to 4 seconds. Still reads cvs correctly. Is running Propack.When not connected to elink the time stays as set, but of course, is not doing anything.On my Win10 laptop, when connected to the elink, I get exactly what you say, except it defaults to 8 seconds. Doesn't read cvs. Is running standard Railmaster in evaluation mode..When not connected to elink the time stays as set, but of course, is not doing anything. Have you queried this with HRMS? ps. both up to date. Link to comment Share on other sites More sharing options...
