shaun_cassidy Posted January 21, 2016 Share Posted January 21, 2016 I am new to using my Select and have inadvertently assigned multiple addresses to individual locos, and consequently more than one loco will activate, when I wish a specific loco to move. Is there a way of clearing the assigned addresses from locos and reassiging a single address?I know the select can be cleared, but not the locos? Link to comment Share on other sites More sharing options...
Rog RJ Posted January 21, 2016 Share Posted January 21, 2016 Just give them a new address, no need to clear old addresses first. Link to comment Share on other sites More sharing options...
Chrissaf Posted January 21, 2016 Share Posted January 21, 2016 Cassola, welcome to the forum with your 1st post..Since the Select doesn't have a separate 'programming' output. I would recommend having a short length of 'programming' track put to one side with its own individual DCC power connector attached. Then when you need to program a loco you can then detach your track from the Select output and connect your dedicated piece of programming track instead. That way, you have no chance of replicating your error again..Remember, should you (or have already) install(ed) Accessory Decoders for points, then these also have to be isolated from the track output when programming a loco on the track. So having a separate programming track piece, eliminates the risk of compromising the Accessory Decoder configurations as well. A 'win win' situation..As RJ says, just overwrite the incorrect loco addresses with the correct ones. Just remember to have only the loco being programmed on the programming track. Link to comment Share on other sites More sharing options...
Flashbang Posted January 21, 2016 Share Posted January 21, 2016 HiAlso dont forget with the Select you can only use address numbers in the range of 1 to 59. Link to comment Share on other sites More sharing options...
