j50 seems sounds very noisey?
morley00
Posted
hi there everyone.   i have just put a new dcc concept 21 pin convert to 8 pin  into my j50  then started to run it in with out the body on to make sure its running welll but as it moving its sounds bad  or like old 1980 motor. i am using a nce pro cab i have also bought a j15  and run like a dream quiet . i recieved it at christmas from hornby has any one had the same problem ?   or is it the chip do i need to use a 8 pin would it make a difference
any advice is welcome
Posted
I doubt the number of pins will make any difference to the noise.
if you can, put it back into DC rig with a decoder blanking plug and run it like that to assess the noise.
it may just need some (sparingly applied) lube.
Posted
hi just to reply to wtd and raf 96  thank for advice i    j50 is proforming well  as sugested i ran her on dc
still abit  noisey but  eventuly  noise ruduced also lube her up as well not to much tho thank for the advice
