Chris Surrey Posted January 29, 2016 Share Posted January 29, 2016 I have been using programmable keys for a while but they have recently run into problems. These being:a) one or two have simply stopped working; andb) I can delete keys but cannot create them. When I try to create, I can access the function drop down list and the next drop down - the one where you select the function (eg the sound you want to play) but the description box remains greyed out and the button cannot be saved.Anyone else having a similar experience? Link to comment Share on other sites More sharing options...
St1ngr4y Posted January 29, 2016 Share Posted January 29, 2016 Hi Chris,I'm pretty sure I had this some time ago, and I think I reported it as a bug through the online system. In the end, I just gave up and haven't tried to use them since. If you are having these problems, I would suggest re-reporting the symptoms through the online help system.Ray Link to comment Share on other sites More sharing options...
AncientMariner Posted January 30, 2016 Share Posted January 30, 2016 Seems to work correctly here with rev 5 AM Link to comment Share on other sites More sharing options...
Chris Surrey Posted January 31, 2016 Author Share Posted January 31, 2016 Thanks Ray - have raised a ticket and am still in correspondence with Support as their first suggestion (delete the ProgButtons.dat file and recreate the buttons) did not work - still cannot create buttons. But having saved the file before deleting it, have fixed the problem by manually amending the ProgButtons.dat file in Notepad to add the new buttons I require. Link to comment Share on other sites More sharing options...
