olly Posted January 30, 2016 Share Posted January 30, 2016 Last night I was giving my TTS scotsman a run and all of a sudden the running sound became distorted for no reason. I have tried resetting the decoder sound but it's still the same very crackly and distorted it sounds like the speaker has blown or something.has anybody else here and this problem? This is the second TTS Scotsman I've had the first one would not run properly and had lots of defects to the model. is there anyone more senior in customer care I can contact ? I've heard others on here mention Mark Lodge ? Link to comment Share on other sites More sharing options...
NormanQ4 Posted January 30, 2016 Share Posted January 30, 2016 You've got it right, Mark is your man. Link to comment Share on other sites More sharing options...
Yelrow Posted January 30, 2016 Share Posted January 30, 2016 Mark, is the Customer Services Manager, particularly helpful, but you will need to ring him, and speak in person. He receives so many emails, to make that way of contacting, difficult. john Link to comment Share on other sites More sharing options...
olly Posted January 30, 2016 Author Share Posted January 30, 2016 normanQ4, yelrow do you have the phone number for mark ? Link to comment Share on other sites More sharing options...
Yelrow Posted January 30, 2016 Share Posted January 30, 2016 Olly, 01843/233/525. you need to ask for him to ring you . He always does, unless, by pure fluke, he answeres himself. john Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 30, 2016 Share Posted January 30, 2016 And if you lose this post, the number John has given you is just the Contact Us number from the bottom of the website. Link to comment Share on other sites More sharing options...
olly Posted February 25, 2016 Author Share Posted February 25, 2016 I have finally received my flying Scotsman back from Hornby this morning after over three weeks yesterday they sent me someone else's class 67 by mistake the paperwork was for my address and the flying Scotsman speaker repair under warranty .I don't know how anyone could get them mixed up! I am really not happy about the level of customer care I have received from hornby . I don't think they are really interested in the customers. I did say to them when I first contacted them would it not be easier to send me the speaker or the decoder whichever was the most likely to have been the problem so I could have fitted it myself. but they said they couldn't do that. if I have the same problem again I will just buy replacement speaker and fit myself it is not worth the hassle of going through hornby customer care. you never know whether you will get your locomotive back or not and have to make numerous phone calls. Link to comment Share on other sites More sharing options...
96RAF Posted February 25, 2016 Share Posted February 25, 2016 If you had whipped the top off that class 67 while you had it you would have found an 8 ohm speaker according to the manual.i suggest if you change your speaker that you go for that rating as the TTS amplifier is stated as 1.68w output @ 8 ohms also according to the manual Link to comment Share on other sites More sharing options...
olly Posted February 25, 2016 Author Share Posted February 25, 2016 I don't think 67 had sound RAF96 and it wasn't mine so I didn't want to touch it hornby had sent me someone else's loco as it had their name and address on .yes if I have too change it myself again will use 8 ohm 2 watt . the ones hornby fitted to the tts locos are only 8 ohm 1 watt . you can buy 28 mm 8 ohm speakers from china for about 60p to 90p on ebay and a lot less if you order in bulk . I can't understand why hornby have used such low quality speakers I know the TTS sound is supposed to be budget but it wouldn't have cost much to put a slightly better speaker in them. Link to comment Share on other sites More sharing options...
Fozzy Bear Posted February 27, 2016 Share Posted February 27, 2016 I don't think 67 had sound RAF96 and it wasn't mine so I didn't want to touch it hornby had sent me someone else's loco as it had their name and address on .yes if I have too change it myself again will use 8 ohm 2 watt . the ones hornby fitted to the tts locos are only 8 ohm 1 watt . you can buy 28 mm 8 ohm speakers from china for about 60p to 90p on ebay and a lot less if you order in bulk . I can't understand why hornby have used such low quality speakers I know the TTS sound is supposed to be budget but it wouldn't have cost much to put a slightly better speaker in them.Because the factory in China used the cheapest speakers they could get that conformed to the specs sent to them from Hornby. The Scotsman TTS engines just seem to be rubbish. Cheap nasty motors and now speakers in a loco that costs top dollar. Link to comment Share on other sites More sharing options...
