midway Posted November 4, 2011 Share Posted November 4, 2011 I have linked two points are per instructions but they will not change to open the same line.they open together but in opposite directions I have tried manual reseting one but to no availand have rechecked wiring and also tried reversing wires to one of the points without success.anyideas please. Link to comment Share on other sites More sharing options...
stevecamden Posted November 4, 2011 Share Posted November 4, 2011 Not completely sure I understand what you mean, but I assume they are connected to a point decoder ( the two points wired into one decoder slot?) If you swap the red and green wires over on one of the two points they should throw in the same direction. Again, I am assuming that you have the motors mounted on the same side.Perhaps I have mis-understood. But from what I can ascertain, there is power to the motor and the points are moving freely.Steve Link to comment Share on other sites More sharing options...
