Couplin Conversion
Buckeroo
Posted
I'm not familiar with Mehano kit. Do the items have NEM sockets? If so, just unplug, and replace with a tension lock.
If the coupling is made as part of the frame, then you will have to resort to surgery.
Posted
Posted
If the coupling is made as part of the frame, then you will have to resort to surgery.Thanks for info, looks like surgery so i don't think I will bother.
Posted
 You will have to be careful as the coupling height will be different. Convertting HO stocks couplings to work with OO scale can be tricky and often not worth it
Thanks for your advice. I do.t thimk i have the shill do do a conversion
