Jimbo1707820979 Posted February 1, 2016 Share Posted February 1, 2016 Hello All. I ask this question because I have 2 locos with the address of 6 and neither of them will run properly -or at all, sometimes -though they both run very well on my local dealers track.I don't think my track is at fault since other locos are running perfectly well. Nor is there visible dirton the wheels or pick-up areas on the locos. So I am now trying to identify the cause of the trouble. The Select went back to Hornby last Summer for updating and is only about a year old.Meanwhile I plan to re-address those two locos but I would still like to know the answer about a possible duff number. So any input would be appreciated. Link to comment Share on other sites More sharing options...
Rog RJ Posted February 1, 2016 Share Posted February 1, 2016 Always worth resetting the Select, just in case. Link to comment Share on other sites More sharing options...
Howbi Posted February 1, 2016 Share Posted February 1, 2016 @Jimbo...........The other day you said you were going to re-address your locos with your Elite controller.....Why don't you do just that with these 2 locos and see how they run on the Select..........if the same problems persist I would suggest you reset CV8 to '8' to return the decoders to their default, give them a trial run on 003 then if all is well re-address to your desired number...........you may also benefit from resetting CV29 to '2' to turn off DC running. HB Link to comment Share on other sites More sharing options...
Fishmanoz Posted February 2, 2016 Share Posted February 2, 2016 There have certainly been previous instances, none recent that I can remember, where specific addresses have refused to work with particular locos. Solution has been to not use them and change. I don't think it has been firmly established previously whether it was decoder or controller. I would think decoder more likely I agree that resetting of both decoder and controller is the most likely way to fix the problem. Link to comment Share on other sites More sharing options...
Jimbo1707820979 Posted February 2, 2016 Author Share Posted February 2, 2016 Thanks, gents.I have just been studying my Elite manual with a view to changing the 2 loco addresses as kindly suggested by howbiman. To avoid complications with "him-who-must-be obeyed" (5 year-old boy) I am setting up a short straight track in an easily-concealed cupboard drawer, with the as-yet-unused Elite sitting alongside. S.O.E. or La Resistance would be proud of this sneaky move on my part. A bas Les Boches ! Then I'll see if they run OK on the Select layout.Lovely avatar, Rog, I'm drooling with envy. Haven't yet even managed a static one myself. Though I'm a bit worried about resetting the Select. But Page 19 of the manual seems straightforward so I will take the plunge ("worries" result from previous horrific blunders on my PC's over the years esp. when I was teaching myself how to use them -no local "guru" unfortunately). I'm reassured by the manual's " DOES NOT REMOVE ADDRESSES FROM LOCOMOTIVES".So I conclude I can then resume operating the locos as before, without any complicated key-pounding.Later, hopefully, full use of the Elite ! 😇 Link to comment Share on other sites More sharing options...
Howbi Posted February 2, 2016 Share Posted February 2, 2016 @Jimbo...........You are quite safe resetting the Select controller because the loco addresses are only held in the decoders.........the Select does not have a memory............when you get into using the Elite, you can give each loco a name which shows on the screen when the address is selected but this list is deleted when you reset the Elite controller.............needs a lot of patience if you have to re-type 30 or more loco names again 🤔 HBJust a thought............in case you had a concern, the Elite will respond to the same addresses you allocated via the Select. HB Link to comment Share on other sites More sharing options...
Jimbo1707820979 Posted February 3, 2016 Author Share Posted February 3, 2016 @HBThanks again. This confirms what I had hoped about the Select. I am going to reset it right away. 😆 Link to comment Share on other sites More sharing options...
