Pietrarsa Posted February 1, 2016 Share Posted February 1, 2016 Hi all Finally I came across the Railmaster world...Now I'm testing things, cv programming, routes, programs, etc.It happens that when I programmed steps with 2 program chains, at first it worked (on main screen, due to the limitation of testing chain program lines), but the second time I lauched the program, there the software freezes, forcing windows to close it.I restarted RM, retried the same program, with same freeze results.I deleted the program, rewrited lines back, same stuff.Then I opted for including prog lines instead of chain and it worked.Is there anyone here that experienced something similar?I must say that programming interface could be better, some "line dragging" feature would be appreciated, as "copy&paste" and "shift select" for multiple line movings. Here is a video of a simple start&stop program on my layout. Any suggestion anyone? Link to comment Share on other sites More sharing options...
St1ngr4y Posted February 1, 2016 Share Posted February 1, 2016 Hi Ciro,Do you have three programs? Program A and Program B contain "ordinary" program lines, then Program C which contains:-Chain Program AChain Program B ?Ray Link to comment Share on other sites More sharing options...
Pietrarsa Posted February 2, 2016 Author Share Posted February 2, 2016 Hi Ray yes, it's like that: Prog C contains "ordinary route" line commands, then chain Prog A, then changes route, then chain Prog B. Prog A & B contain only "ordinary" program lines (announcing departing, lights on, shunt, cruise, announcing arrival, shunt, stop, lights off) for 2 different locos.Prog A & B they run without problems when launched singly. Link to comment Share on other sites More sharing options...
St1ngr4y Posted February 2, 2016 Share Posted February 2, 2016 Hi Ciro,I have lots of programs like that, but I haven't had Railmaster freeze up as you describe. I think you should report it through the online help system. HRMS may ask you (by email) to send copies of all three programs, so they can find out what may be going wrong.Ray Link to comment Share on other sites More sharing options...
Pietrarsa Posted February 2, 2016 Author Share Posted February 2, 2016 These are the 3 programs:/media/tinymce_upload/e91b3b108a36d0570592af34d408c72a.jpg /media/tinymce_upload/049fd8f511176bfb5651c61fc3bc1918.jpg /media/tinymce_upload/d722ab1485b941097a448fa902ab1712.jpg Link to comment Share on other sites More sharing options...
St1ngr4y Posted February 3, 2016 Share Posted February 3, 2016 Hi Ciro,These programs look fine to me. However, you could try adding an extra "play sound" command at the end of program 3:- 145 Program Command Play sound etc...... The only other thing I can see is the name of the program "Chain" - this may be confusing it - try changing the name 😀EditI've just noticed something which may affect things. There is a small bug in Railmaster, which I reported a few months ago, whereby when running a program containing chain commands, RM starts the program clock before it has finished merging the chained programs. What I have done with my programs is to insert at line 0 a Program Command Message "Please wait...", then the next command comes at 10 seconds.I would suggest in Program 3 you add 10 seconds to each program line, then enter a Message command at line 0. Ray Link to comment Share on other sites More sharing options...
