darrenmarkgreen Posted February 8, 2016 Share Posted February 8, 2016 Hi all,im trying to design my layout but cant get the track pieces to line up and join together when using cureded points to go from 3 radus to 2 radus( as pictured in the track gemortery pdf document ive seen). so does anybody know that track piece number i should be using.thanksdarren Link to comment Share on other sites More sharing options...
Chrissaf Posted February 9, 2016 Share Posted February 9, 2016 This issue has been discussed before. See this previous post:https://www.hornby.com/uk-en/forum/post/view/topic_id/234/?p=1.Based upon the linked thread above, It would appear that Hornby have not produced a specific piece of set track designed for this purpose. The final solution presented in this linked thread does not appear to be an elegant one, but many in the thread say it works. Personally I would use a short length of flexitrack in your situation. Link to comment Share on other sites More sharing options...
96RAF Posted February 10, 2016 Share Posted February 10, 2016 The linked discussion has some people agreeing and some not but Try R643 which is 2nd radius and matches the inner track of the curved point - look at the geometry download and you will see the logic. Link to comment Share on other sites More sharing options...
