Howbi Posted February 11, 2016 Share Posted February 11, 2016 Just fitted the Hornby X9659 4pin decoder into the Sutton Terrier.......firstly, prised off the smoke box door then removed the weight which I then cut in half horizontally.........the bottom half then refitted back into the smoke box.........then using a 3mm drill, cut a slot in the internal bulkhead to facilitate feeding the decoder leads through...........I prised open the minute lugs in the decoder socket to release the wire terminals which made soldering to the motor and pick-up wires much simpler & using heatshrink to seal exposed joints..........NB.....I covered the top of the motor with very thin flexi card as it is possible for wiring pushed up into the space could impinge the rotating armature.....so a satisfactory job done and the loco runs extremely well no doubt due to having 6 wheel pick-ups. HB Link to comment Share on other sites More sharing options...
tersono Posted February 16, 2016 Share Posted February 16, 2016 Good to read. I've got a couple of Terriers that need decoders so will be trying something similar fairly soon :) Link to comment Share on other sites More sharing options...
Bulleidboy Posted February 16, 2016 Share Posted February 16, 2016 There is another posting on here - somewhere!!. You can attach both the Hornby R8249 and the Digitrax DZ125 decoders to the side of the motor with bath sealant. Wiring is the usual way. No need to remove, cut any of the weights. The decoder will sit between the motor and the body side. Link to comment Share on other sites More sharing options...
Howbi Posted February 16, 2016 Author Share Posted February 16, 2016 @BulliedBoyWell I wish I'd seen that post before I started sawing & drilling, BB...........would have saved me a lot of hassle. 😎 HB. Link to comment Share on other sites More sharing options...
pidder Posted February 19, 2016 Share Posted February 19, 2016 Is there a service sheet for this engine, particularly BR 0-6-0 R 2165 B? Link to comment Share on other sites More sharing options...
Fishmanoz Posted February 19, 2016 Share Posted February 19, 2016 Did you look at the sheets on this site for one? Link to comment Share on other sites More sharing options...
pidder Posted February 20, 2016 Share Posted February 20, 2016 Fishmanoz sorry, not sure what you are referring to, I am just seeking the number of an appropriate Hornby service sheet. Link to comment Share on other sites More sharing options...
96RAF Posted February 20, 2016 Share Posted February 20, 2016 @pidderFishy is asking if you have looked for the service sheet for you R2165 loco on the Hornby main website - Help & Advice - Service Sheets area. Go here https://www.hornby.com/uk-en/downloads/view/index/cat/2/ then either type in R2165 into the search box(where it says Enter a SKU, product name or resource name in the text field below) and download the result or look for service sheet by number HSS216 in the folders. Link to comment Share on other sites More sharing options...
pidder Posted February 20, 2016 Share Posted February 20, 2016 RAF96 Thanks, found the service sheet, but doesn't show removal of body from chassis, presume just the two small screws at the rear end... Link to comment Share on other sites More sharing options...
Howbi Posted February 20, 2016 Author Share Posted February 20, 2016 Hi Pidder............Ignore the screws that hold the couplings..........you need to undo the the screw at each end of the bottom plate then the body lifts off. HBps.......the operating and maintenance instructions should be in the box and the model no. is R3248. Link to comment Share on other sites More sharing options...
96RAF Posted February 20, 2016 Share Posted February 20, 2016 @hbmstill the same service sheet as I pointed him to.cant find a maintenance sheet though. Link to comment Share on other sites More sharing options...
pidder Posted February 20, 2016 Share Posted February 20, 2016 Thanks both, I have the body off now. Not sure if my X9659 decoder will fit as bulleidboy suggests, will try it. Link to comment Share on other sites More sharing options...
Howbi Posted February 20, 2016 Author Share Posted February 20, 2016 @hbmstill the same service sheet as I pointed him to.cant find a maintenance sheet though.Hi Rob, The one that came in the box is more detailed than the HSS..........if Pidder needs it, I could scan a copy & post on Monday. HB. Link to comment Share on other sites More sharing options...
pidder Posted February 20, 2016 Share Posted February 20, 2016 howbiman That was quick, thanks for the offer, but all I wanted was advice on how to remove the body, which I've now done. next step to fit a decoder... Link to comment Share on other sites More sharing options...
GWR LNER fan 4472 Posted February 20, 2016 Share Posted February 20, 2016 I had one of these locos in 2012 (R3117 number 32670 in early BR black) and I had to store the decoder in the little bit behind the bunker with wiring going under the body to the motor. Don't know what your model is like though it may be slightly different. Link to comment Share on other sites More sharing options...
pidder Posted February 20, 2016 Share Posted February 20, 2016 GWR & LNER Thanks, I'm considering what is best decoder... Link to comment Share on other sites More sharing options...
GWR LNER fan 4472 Posted February 20, 2016 Share Posted February 20, 2016 I've got the four pin one (X9659) as it's the only one that fits in most small engines, mainly 0-4-0s but also a few 0-6-0s. Link to comment Share on other sites More sharing options...
poliss Posted February 20, 2016 Share Posted February 20, 2016 Have you looked at Z Scale decoders pidder? Link to comment Share on other sites More sharing options...
pidder Posted February 20, 2016 Share Posted February 20, 2016 I have an X9659, probably my best option. Still not sure if it will go alongside the motor as bulliedboy suggested. Link to comment Share on other sites More sharing options...
dh2807 Posted February 20, 2016 Share Posted February 20, 2016 I have fitted a digitrax DZ125 decoder using double sided tape to the side of the motor which removes the need to cut and dismantle any of the loco body.....easy! Link to comment Share on other sites More sharing options...
pidder Posted February 20, 2016 Share Posted February 20, 2016 dh2807 Thanks, my X9659 should go in ok then. Link to comment Share on other sites More sharing options...
