Smithy58 Posted February 14, 2016 Share Posted February 14, 2016 Having just upgraded to Railmaster version 1.64 It seems I now have to click on the buttons twice as nothing seems to happen when I clicked once, has anyone else experienced this problem? Link to comment Share on other sites More sharing options...
Chrissaf Posted February 14, 2016 Share Posted February 14, 2016 Not exactly, I found I have to give a slightly longer single click. In other words click and hold just for a fraction of a second longer than one would normally do. As you say, a quick click doesn't seem to register. Maybe the timing of the soft button scanning routine has been changed within the RM software. Link to comment Share on other sites More sharing options...
Smithy58 Posted February 15, 2016 Author Share Posted February 15, 2016 Not exactly, I found I have to give a slightly longer single click. In other words click and hold just for a fraction of a second longer than one would normally do. As you say, a quick click doesn't seem to register. Maybe the timing of the soft button scanning routine has been changed within the RM software.Well if this is the case thempeopleare going to find it even more difficult to use as you have a click setting for using in Windows software and a completely different click for the Hornby software whic will make it extremely frustrating to use I wouldsuggest that Hornsby should urgently revert, it back to the old setting of running with the windows default Link to comment Share on other sites More sharing options...
Smithy58 Posted February 15, 2016 Author Share Posted February 15, 2016 Apologies for spelling and words stuck together Link to comment Share on other sites More sharing options...
Mobileadam Posted February 15, 2016 Share Posted February 15, 2016 Interesting thread. As a new user I found the controls would not 'settle' for quite some time and logged a bug which after some extended testing I found that the speed settings aren't saved or set until the little tooltip disappears from the speed control ( this tooltip display the decimal of the current speed). HRMS has confirmed the problem, said it was harder to fix than first thought but would work on it. This was a few weeks back. I found it a problem as if I moved my mouse off the speed control to do something else the slider went up or down relative to the mouse position - hence the need to wait for the tooltip to disappear before moving the mouse. I occassionally get commands missed but that I think is another problem entirely! Link to comment Share on other sites More sharing options...
NormanQ4 Posted February 15, 2016 Share Posted February 15, 2016 Apologies for spelling and words stuck together Why don't you just use the spell checker (ABC over tick button, beside smiley face) before you hit the reply button, it works a treat. Link to comment Share on other sites More sharing options...
NormanQ4 Posted February 15, 2016 Share Posted February 15, 2016 I also have the issue with the slider moving when the cursor is on an adjacent part of the screen.Does any one know of a fix? Link to comment Share on other sites More sharing options...
96RAF Posted February 15, 2016 Share Posted February 15, 2016 I was fiddling yesterday and noticed the same need for a double click effect in expanded throttle. I thought it was just my mouse so didnt report it in. Also in expanded throttle clicking stop button didnt pull the slider back to zero and the loco kept on going. I had to use the small throttle to stop it. Another thing I've seen before and still find occasionaly is the mouse sticks to the expanded throttle and I cant release it - it keeps moving the throttle around the screen following the cursor. I'll check later to see if Chris's long click works any better. Maybe v1.64 is a bit buggy. Link to comment Share on other sites More sharing options...
WilliamDavid Posted February 15, 2016 Share Posted February 15, 2016 I thought my tablet was just acting up again.The loco control is now rather erratic, and, may I say, dangerous to the health of my expensive locos. Link to comment Share on other sites More sharing options...
Fishmanoz Posted February 15, 2016 Share Posted February 15, 2016 All of you should report the problem back to HRMS via the email facility in the Help window of RM as it's clearly something they should look at. Oh, and it would be good if you stopped using that blue button at the bottom of people's posts, just the box at the bottom of the page and the green Reply button to avoid this thread clogging up with multiple copies of previous posts. Link to comment Share on other sites More sharing options...
Smithy58 Posted February 18, 2016 Author Share Posted February 18, 2016 Just to let you know, Railmaster support have suggested I download again and reinstall Link to comment Share on other sites More sharing options...
Chrissaf Posted February 18, 2016 Share Posted February 18, 2016 Standard stock answer from HRMS..The analogy is the IT department at work........."Have you turned it off and on again" Link to comment Share on other sites More sharing options...
St1ngr4y Posted February 18, 2016 Share Posted February 18, 2016 ......... the speed settings aren't saved or set until the little tooltip disappears from the speed control ( this tooltip display the decimal of the current speed). .........I control my trains mostly through running programs, but this week I noticed that the little tooltip mentioned above to display the decimal of the current speed is ACTUALLY displaying (128 - current speed). Apologies if this has been mentioned elsewhere already.Ray Link to comment Share on other sites More sharing options...
Mobileadam Posted February 18, 2016 Share Posted February 18, 2016 @Ray,I must admit I didn't check or acknowledge the value of the speed value displayed when selecting the slider. I was interested in the speed not being set or the cursor latching to the slider control until the tooltip disappeared. I still find not all commands go through, sometimes it loses connection for a while and other times my status lights stays green for quite some time before returning back to normal so accuracy of speed control is pretty limited for me!!! I'm happy if my locos move and then stop when I ask! Link to comment Share on other sites More sharing options...
NormanQ4 Posted February 24, 2016 Share Posted February 24, 2016 I'm also having issues with the slider continuing to move in unison with the cursor even though it is on another part of the screen, and having to double click on the slider to regain control.On one occasion this resulted in a crash as the stop button also failed to function.I sent an email from within RM on Friday morning (UK time) and received an acknowledging email reply but no other contact so far.Perhaps if they're monitoring the RM forum I'll get a response soon. Link to comment Share on other sites More sharing options...
NormanQ4 Posted February 26, 2016 Share Posted February 26, 2016 I think RM Support should change they're name.Six working days have passed and still awaiting a response.I sent them another email yesterday and with no other method of communication the waiting is very frustrating especially heading into yet another weekend.Support? Link to comment Share on other sites More sharing options...
Mobileadam Posted February 26, 2016 Share Posted February 26, 2016 The support department is going through emails as I've just had responses from my issues logged this week. Alas, no solution to this problem, nor the short circuit message not appearing unless I use alternative comms which then leads to RM freezing. Looks like I have to make compromises in the usability. Shame. Link to comment Share on other sites More sharing options...
St1ngr4y Posted February 26, 2016 Share Posted February 26, 2016 I think RM Support should change they're name.Six working days have passed and still awaiting a response.I sent them another email yesterday and with no other method of communication the waiting is very frustrating especially heading into yet another weekend.Support? I think you need to have a lot more patience - try thinking in months rather than days. The company who develop and maintain Railmaster are not Microsoft or Apple. They are a relatively small company with limited resources.Ray Link to comment Share on other sites More sharing options...
NormanQ4 Posted February 27, 2016 Share Posted February 27, 2016 Come off it Ray, I just checked my calendar, and it is still 2016 "try thinking in months rather than days" seems a ridiculous and out of date statement.If you are in the business of giving support then that's what your expected to do and if you can't do it in a timely fashion then your in the wrong business.Computer program support is a NOW business and nobody in their right mind would want a support service that responded in months.I know they are a small organisation and on the whole they do a great job, but taking a week just to respond to a request for assistance is unsatisfactory.If someone tells me they'll get back to me in two days and I'm still waiting after six days with no contact from them then I don't think that I could be described as being impatient. Link to comment Share on other sites More sharing options...
Fishmanoz Posted February 27, 2016 Share Posted February 27, 2016 Given their usually excellent response, including on weekends and public holidays, I think I'd be cutting them a little slack this time Norman. And looking carefully at Ray's post, I thought glimpsed his tongue in his cheek too. Adam, good you have some answers now, even if problem not solved. Don't forget development is ongoing with RM so you may well find the problem solved with an update coming your way soon. Link to comment Share on other sites More sharing options...
96RAF Posted February 27, 2016 Share Posted February 27, 2016 I had a reply from HRMS yesterday about two of my problems asking for more information, which I have sent to them, so they are about and they are working problems.A previous response I got just after v1.64 was issued, but hadn't fixed my particular problems, was they wanted to get a stable version out for the important problems (I think the issue at that time was signalling) and they would then turn attention to all the other reports in hand. So I patiently wait for the next iteration. Remember any changes to the code has to go through a procedure to check it is stable enough for sign off, etc before we even get to try it and as some problems are more difficult to fix than others the team has to make judgement call on what gets fixed in this next revision and what has to be worked later. Link to comment Share on other sites More sharing options...
Smithy58 Posted March 6, 2016 Author Share Posted March 6, 2016 Have finally downloaded and reinstalled software , seems to work ok but v wary as before one of my locomotives didn't stop and went off the board when testing a section of track out. Link to comment Share on other sites More sharing options...
Fishmanoz Posted March 6, 2016 Share Posted March 6, 2016 That sounds like DC Runaway you are experiencing Smithy. Not RM's fault, usually caused by dirty track and wheels etc, although some decoders also seem to be more sensitive to it after they've had problems like being subjected to shorts. Fix once and for all by turning off DCC Running in CV29. Link to comment Share on other sites More sharing options...
96RAF Posted March 7, 2016 Share Posted March 7, 2016 HRMS came back to me again over the weekend, asking more questions, but saying I can't fire two sets of paired points from the same PAD, due to depleted internal CDU capacity, unless I wait 30 seconds for a recharge - odd but I actually can using my relay system, Followed immediately by the two singles on the other two ports. they also said that surface mount point motors draw more current than the underfloor ones. I disagreed purely on the basis of physical characteristics of both motors - one small and lightweight and the other much more the heavyweight, but I need some to find the associated specs to prove it. Anyone got these? HRMS are also still struggling with the large throttle selection for stop only slowing the loco to shunt due to the small throttle slider moving to shunt not stop, when controlling a dual decoder loco - e.g. Class 395. They have rigged a dual decoder loco but can't replicate the problem, so if anyone else has seen it then please report it in. i don't think the double click thing has gone away yet on my machine. It often seems to need one click to get its attention then one to execute the command, but frustratingly not all the time. Link to comment Share on other sites More sharing options...
