winston churchill train pack
latchford
Posted
Hi all have received the above nice model but for one issuie,the van used to convey the coffin has no nem coupler pockets if think it's a repainted  item from rovex days shame as it does not look right. Any comments welcome ☹️
Posted
This would be better in the General section latchford, you I'll get more replies.
What sort of coupling does it have?
Edit: I've just had a look. Cut the couplings off and attach some new ones. I've just done that to some coaches.
Posted
/media/tinymce_upload/86216ebc60d27ac0aa412dfd87f0b98f.jpg
 The 'Utility Van' first appeared with the original Tri-ang 9" carriages way back in 1958. This is the page from the 4th edition catalogue (some of the 9 inch coaches actually appeared the year before.) The Funeral van is a recent version, but is basically the same model. It has the old Mark 1 bogies.
The old R226/R227 is not 100% accurate. The roof is wrong, it should have a eliptical profile, the planks are denoted by raised lines and not grooves, the underframe trussing is from the 9 inch coaches, loosely based on Mark 1 girder trusses, and should really be rods supported by queen posts, the bogies should be Fox pattern, the corridor connections are too small, and the doors are too thick. Roxey Mouldings do a kit to improve some of these features, but I also found that the roof is better tackled by grafting two and a half roofs from the SR ventilated goods van together.
  • 1 month later...
Posted
I would imagine the luggage van in the set is the same as this - R4451    Pullman Luggage Van .
That is the one.
It was issued as a "solo" model a few years ago, before the Train Pack.
There is one other difference between th emodel and the real van used for the funeral train.
The real one has a pair of windows added to the centre pairs of doors each side.
The model doors are compromised, as they were made to be openable..."With 12 opening doors"...
http://www.ehattons.com/33073/Hornby_R4451_SR_Bogie_Luggage_Van_Pullman_livery_as_used_for_Sir_Winston_Churchill_s_funeral/StockDetail.aspx
Posted
For someone with shakey hands and is not so brave as to just start cutting in case I ruin something, can you expand on how you would cut the old-style hornby coupling off a coach and how you would attach a new one?
Posted
There are quite a few variation of modern couplings with different ways to fit them. Have a look on this site send the Bachmann one. I just cut the old ones off with wire cutters and then find the best ones to replace them. Usually I find a nut send bolt is the best way.
Nut just about visible in the photo.
/media/tinymce_upload/cc7a65025421b466e002e3cee753ceeb.jpg
Posted
 I had the same problem with my Imerial Airways set and even contacted Hornby about the possibility of supplying wide couplings with the Winston Churchill set but to no avail. However I got round the problem with the Imperial Airways (green) version of the same van by fitting Bachmann bullied bogies. Although these do not have nem pockets they are available with narrow coulings. In addition (an my real reason for changing them) the bogies are of the corrct SR pattern and not a BR Mk 1.
Note I did need to get nuts, bolts and washers to get them to fit at the right height.
