debe45 Posted February 16, 2016 Posted February 16, 2016 Has anyone used the Modratec Wire in Tube points control. I am planning to use it as I like the idea of actually pulling a little points lever, and did not like the points motors much. I did not use a CDU.
LCDR Posted February 18, 2016 Posted February 18, 2016 I am contemplating making my own using curtain wire as an outer with bike brake cable (or similar) inner.
debe45 Posted February 18, 2016 Author Posted February 18, 2016 Hi LC&DRHow will this be connected to the actual points and how will you operatte this ie. what switch, knob or what will you pull, push etc. to operate the points.
Chrissaf Posted February 18, 2016 Posted February 18, 2016 Some people use electrical slide switches see photo. Then the switches can double up to provide switching for things such as signals or frog power (electrofrogs) or LED indicators showing point position.
