salmontrout Posted February 22, 2016 Share Posted February 22, 2016 Hi With my select which I now only want to use as back up, with a shortcircuit the overload came in and shut everyhing down. What protection is their with railmaster and e link. Link to comment Share on other sites More sharing options...
96RAF Posted February 23, 2016 Share Posted February 23, 2016 A short circuit to the eLink will result in a shut down indicated by RM. you then have to clear the short and reset the eLink by pressing the little red button found inside the big red stop button. Link to comment Share on other sites More sharing options...
Fishmanoz Posted February 23, 2016 Share Posted February 23, 2016 The Stop button is on the RM screen. Link to comment Share on other sites More sharing options...
salmontrout Posted February 23, 2016 Author Share Posted February 23, 2016 Hi, thanks. I have found the little reset button and used it but not sure what shows that there is an overload. What should I look for other than nothing running? Link to comment Share on other sites More sharing options...
96RAF Posted February 24, 2016 Share Posted February 24, 2016 RM flashes up a warning dialogue box (or it did - search RM forum for short circuits). Link to comment Share on other sites More sharing options...
Mobileadam Posted February 24, 2016 Share Posted February 24, 2016 The short circuit message is an odd one. Now that I've changed my ini settings to have a better connection and not get freezes (and incordance with the RM set up instructions on the forum) I no longer get the short circuit message. It used to work and reset as expected, however with the configuration changes (bascially Check Controller = 0) the eLink goes into safety mode but I find to get everything working again I need to press that little sqaure to reset things AND then exit RM and restart the software before it will work again. Link to comment Share on other sites More sharing options...
96RAF Posted February 24, 2016 Share Posted February 24, 2016 As far as I know it still hasn't been fixed to everyone's satisfaction. Link to comment Share on other sites More sharing options...
