magiver Posted February 26, 2016 Share Posted February 26, 2016 Can anyone help? I have just inboxed a new DoG, it runs fine but I can't get any sound. The controllers I have tried are Elite and Elink. Link to comment Share on other sites More sharing options...
choralc Posted February 27, 2016 Share Posted February 27, 2016 magiver, if you can please tell us the steps you have done with each controller members will be able to offer other suggestions other than the following:With the Elite confirm the id. of the loco by running it again (if you have changed it from the default of "3" and it does not run try "3"). If the loco does run please confirm that after pressing the Function key once the display shows F00-F09. Then press '1' on the keypad to turn on sound and confirm that there is indeed no hiss of steam sound. Link to comment Share on other sites More sharing options...
Fishmanoz Posted February 27, 2016 Share Posted February 27, 2016 And when running with eLink and RM, can you please confirm that you have gone into Loco Setup window then called it up by the correct R number from the RM database such that you now have it on screen with all of its sound functions showing correctly in the throttle. Link to comment Share on other sites More sharing options...
96RAF Posted February 27, 2016 Share Posted February 27, 2016 Another thing to keep in mind is TTS will only work properly when the controller is set for 128 speed steps. This is achieved on the Elite by following the Menu to Config and going through th esteps. There is a flow chart in the Elite manual to help prevent you getting lost. Link to comment Share on other sites More sharing options...
magiver Posted February 29, 2016 Author Share Posted February 29, 2016 Thanks to all. Yes I did all of the Adobe and ended up taking it back to my supplier . They also did a full range of tests and confirmed it was faulty. They replaced it straight away.the guys at Hobbytech in Perth Western Australia were great. Link to comment Share on other sites More sharing options...
