Short or overload when tender attached
salmontrout
The tender has a conductive post with the vertical bit being one contact and the plates above it on the tender being the other contact.
On the loco you have a clamp under the drawbar that grips the post (one contact) and two fingers above the drawbar (that get bent all over the place) that bear on the tender plates (second contact).
just make sure the fingers are biased upwards equally to make contact with the tender plates and that the clamp bit is tight but not too tight on the post.
