john_goodwin1 Posted March 19, 2016 Share Posted March 19, 2016 Yet another loco purchased with that damned plug that connects loco to the tender. Princess Arthur of Connaught test run on rolling road and when trying to put away in the box the sodding plug was so tight 2 wires pulled from the plug!!. Is there any way to easily put these plugs in and out?.Another repair to pay for unless Hornby can help. Link to comment Share on other sites More sharing options...
walkingthedog Posted March 19, 2016 Share Posted March 19, 2016 Yes you need tool X6468. Job done 😆 Link to comment Share on other sites More sharing options...
Chrissaf Posted March 19, 2016 Share Posted March 19, 2016 Hornby make a special extraction tool specifically for that task X6468 currently out of stock on the Hornby site. But should be available from other retailers if you Google it..25 in stock here......half price offer @ £1 each.Replacement plug with 4 pre-terminated wires is part number X6113.EDIT: must type faster.....WTD beat me to it by 25 secs Link to comment Share on other sites More sharing options...
Fishmanoz Posted March 19, 2016 Share Posted March 19, 2016 Don't think it was the speed of the typing got him up before you Chris, check his word economy. Link to comment Share on other sites More sharing options...
walkingthedog Posted March 19, 2016 Share Posted March 19, 2016 Short and sweet fishy. I dont read long threads. Link to comment Share on other sites More sharing options...
Yelrow Posted March 20, 2016 Share Posted March 20, 2016 I use Heathers tweezers. john Link to comment Share on other sites More sharing options...
Yelrow Posted March 20, 2016 Share Posted March 20, 2016 When so many posts wrongly get held/ pulled for aleedged profanity, how in our lords name did that one get through. I can fully understand the frustration, but lets have a level playing field. john Link to comment Share on other sites More sharing options...
mjb1961 Posted March 20, 2016 Share Posted March 20, 2016 Hi ,They are a pain ,I chose to leave them connected because of this happening ,you have to cut out some of the polystyrene to get the loco and tender back in but it does prevent any pulled out wires ,,,,,,,, Link to comment Share on other sites More sharing options...
john_goodwin1 Posted March 20, 2016 Author Share Posted March 20, 2016 thanks for all the advice, esecially the extraction tool, never heard of it!!The spare part for the plug and wire, is it easy to fix?? Link to comment Share on other sites More sharing options...
mjb1961 Posted March 21, 2016 Share Posted March 21, 2016 Hi ,the replacement plug with wires will probably need soldering at the motor end ,even useing the extraction tool can be tricky and if you are going to be plugging and unplugging because of a lot of use your bound to have more pulled out wires ,your best bet is to leave them plugged together at all times if possible ,,,,, Link to comment Share on other sites More sharing options...
