Old Bob Posted March 19, 2016 Share Posted March 19, 2016 New to DCC If I put a Hornby Carriage R4068 on the track on its own does it light up ? Link to comment Share on other sites More sharing options...
Howbi Posted March 19, 2016 Share Posted March 19, 2016 When the track is live the Carriages will light up..........can't find R4068, you may have mis-typed the number. HB Link to comment Share on other sites More sharing options...
Chrissaf Posted March 19, 2016 Share Posted March 19, 2016 "can't find R4068, you may have mis-typed the number. HB".I was wondering that too HB. The only R4068s I could find where historical references to some quite old carriages. The R4068s I found, didn't look to have any factory fitted lighting, being dated 1998 / 1999. AFAIK, factory fitted lighting is a fairly modern feature..If the lighting is factory fitted and are dated from a time period that predates DCC and/or not based on LEDs. Then there may possibly be an issue with the higher DCC track voltages burning the lighting out prematurely..In principle, if the carriage has its own lighting pickups on the wheels, then it should light up when placed on the always live DCC track. Link to comment Share on other sites More sharing options...
Old Bob Posted March 20, 2016 Author Share Posted March 20, 2016 When the track is live the Carriages will light up..........can't find R4068, you may have mis-typed the number. HBThanks for your reply The Hornby Carriages are R 4607 & 8 'Composite with Lights' S 150T in green Link to comment Share on other sites More sharing options...
