andel1 Posted March 22, 2016 Posted March 22, 2016 Hi allI've designed my track on rail master according to my layout but the problem I have is that two of my points are at 45 degrees and track master won't let me put them in at that angle it only let's me put them in vertical or horizontal so any suggestions would be most welcome Regards Andrew
Chrissaf Posted March 22, 2016 Posted March 22, 2016 In RailMaster "45 degree points support" require you to upgrade to the RM ProPack about £30 give or take abit. It is an extra 'paid for' content feature..It's all in the RM manual. Open manual in Acrobat Reader press the 'Control Key & F key' together, a search box opens. Type 'ProPack' in the search box and you will be able to jump sequentially to every manual reference to ProPack.
Fishmanoz Posted March 22, 2016 Posted March 22, 2016 Just put in the vertical or horizontal point that fits most neatly. Also doesn't matter whether it's a left hand or right hand point to RM. All it actually knows is that it is a point and it is set left or right, nothing else. So if your real point is left hand and the one that fits more neatly on the schematic is right hand, then use the right hand.
