DavidT Posted March 24, 2016 Share Posted March 24, 2016 Can anyone tell me the correct sequence to address a Train-Tec decoder in Railmaster? Cant seem to get it to work correctly using guide? Thank you. Link to comment Share on other sites More sharing options...
Fishmanoz Posted March 24, 2016 Share Posted March 24, 2016 Traintek loco or accessory decoder? Link to comment Share on other sites More sharing options...
PJ_model_trains Posted March 24, 2016 Share Posted March 24, 2016 Hi DavidT Are you using Train-Tech signals with built in decoder ot a Train-Tech decoder separate? Due to issues with Train-Tech signals (ones with built in decodersgoing back to Oct 2013) HRMS have changed the way you program these signals, you now do it from within the layout design section. I am away from my PC and RM until tomorrow but will look at emails from HRMS tomorrow. Ray and myself were involved with the latest test which fixed most issues, we are waiting for them to finalise the last few issues reported but we have heard nothing since. This could be why they haven't updated the User Guide to reflect the changes as they are still testing and fault finding. I am surprised we have not heard from them as the last attempt corrected most of the more serious issues just leaving a handful of small items to finalise. Link to comment Share on other sites More sharing options...
PJ_model_trains Posted March 25, 2016 Share Posted March 25, 2016 Hi DavidT Note: These instructions are for setting Train-Tech signals that have de-coder in the base of them. These are the latest instructions from HRMS (Hornby RailMaster Support) following fault testing at the end of January and over-ride the manual and Train-Tech instructions. First it is advisable to download and install the latest RailMaster revision from www.powerpos.com/rail-master/rm_setup.exe Open RailMaster and then open the Track Plan, that is the triangle at the top of the screen Right Click on one of the signals in your layout design, the one you want to set up. A box will pop up.Your Controller set to AYour decoder port set to the port you are setting for this signalSignal Type is Train Tech colour light signalWhen you choose your signal type 2 aspect, 3 aspect etc it should automatically complete the SEQ - PORT - SETTINGS for you.Just below these drop down boxes you will see two colour light signals HRMS now state...We have made changes to a few areas of the program to allow 'only the red test button to be used to set the signal address during track design mode'. A slight pause has been introduced when starting up the signals to ensure that the DCC signal gets through to each signal. So to set your signal now, from track plan design, you put your signal into 'learn mode' so they are flashing then click the RED circle signal icon in signal setup, in layout design. Good luck. Link to comment Share on other sites More sharing options...
