geochoice Posted March 26, 2016 Share Posted March 26, 2016 Hi, When I used my previous layout Railaster on startup set all the points to the default position reulting inmany clicks as each set in turn, On my new layout I have redrawn the mimic and everything works just great except despite having Set points signals ticked in my settings for the chosen layout plan, they do not set. Have I missed another setting? Thanks, Link to comment Share on other sites More sharing options...
96RAF Posted March 26, 2016 Share Posted March 26, 2016 If you have the Pro version then you also have to designate for each point in Design Mode what order you want them to start up in, else they wont fire if you leave this field blank - how do I know? - exactly, mine wouldn't set at start up until I told them which order to do it in. Link to comment Share on other sites More sharing options...
geochoice Posted March 26, 2016 Author Share Posted March 26, 2016 Thanks RAF. I have had Pro for a while now but I do not recall needing to set an order of play. Anyway all 21 points have been allocated a number and all set on start up. I did not find any reference to this order needing being set in the manual. Many thanks, George. Link to comment Share on other sites More sharing options...
Fishmanoz Posted March 26, 2016 Share Posted March 26, 2016 The manual tells you about it on pages 6, 23 and 91. It seems to fail to make it clear that it is mandatory to do so under ProPack though. Link to comment Share on other sites More sharing options...
geochoice Posted March 27, 2016 Author Share Posted March 27, 2016 Thanks for that Fishy, some of the manual looks like it evolves from a bad translation, or as it has been added along the way not as lot is in any order, I tried and failed to find solututions in many cases and without you guys would have thrown the towe in a long time ago. Thanks RAF the whole schematic looks and works the part now. Until the next question .......... Link to comment Share on other sites More sharing options...
geochoice Posted March 27, 2016 Author Share Posted March 27, 2016 /media/tinymce_upload/4a19e4ed49e212c16a1fbfc9419686aa.JPG Link to comment Share on other sites More sharing options...
