marlene Posted April 3, 2016 Share Posted April 3, 2016 I have recently used RM and have problems with the double heading setup. Can select the locos for double heading and get DH-0 in the window. There is no green arrow as per the manual so cannot configure anything and will not save the 2 locos as a double header. It appears the missing green arrow is the problem. Any ideas form you wisemen out there Marlene Link to comment Share on other sites More sharing options...
96RAF Posted April 4, 2016 Share Posted April 4, 2016 First off Marlene download the latest version of RM from the link at the top of the RM main page. Run it as Administrator overwriting your existing copy - you won't lose any of your settings or plans, etc, then see if the problem is still there. If it is then report it back to HRMS using the Help facility so if it is a problem they can look at fixing it. Link to comment Share on other sites More sharing options...
marlene Posted April 15, 2016 Author Share Posted April 15, 2016 ThanksI contacted HRMS and they pointed me in the direction of the settings and the fact that the green arrow is only available on the pro version. Changed the no of Double Headers in the drop down of settings from 0 to 2 and it works fine. Link to comment Share on other sites More sharing options...
96RAF Posted April 16, 2016 Share Posted April 16, 2016 As far as I understand it the only benefit PRO brings to the party is that you can state which way a double header loco is facing (is this the GREEN ARROW?),such as Class 20s usually used to run nose to nose and RM PRO lets you do that. Else any double header is a simple pick 2/3 locos from the list, assign a header number and its locked in. With Pro it just remembers the rig for later to save you inputting it again. Link to comment Share on other sites More sharing options...
RDS Posted August 20, 2016 Share Posted August 20, 2016 ... With Pro it just remembers the rig for later to save you inputting it again ... Does it? Mine doesn't. Do I have do do anyything special to get my Double Header to save. Link to comment Share on other sites More sharing options...
96RAF Posted August 20, 2016 Share Posted August 20, 2016 Extract from latest manual - additional features in Pro Pack page 6....Saving of current multiple headers for use the next time the program starts ... then according to page 99 when you,exit RM and have existing live DHs it will ask you,if you,want to save them. Link to comment Share on other sites More sharing options...
RDS Posted August 20, 2016 Share Posted August 20, 2016 @RAF96Thanks. I have just exited RM and it didn't ask or save them. Link to comment Share on other sites More sharing options...
96RAF Posted August 20, 2016 Share Posted August 20, 2016 I would report that in to HRMS as a snag RDS Link to comment Share on other sites More sharing options...
RDS Posted August 20, 2016 Share Posted August 20, 2016 ... (is this the GREEN ARROW?) ... When I first clicked the Green arrow it did not do any special but I realised that in the settings window, there is the ability to select the number of Double Headers you want. When it is set as 1, the Green arrow does not do anything - but if you select more than 1 in the settings winddow, the Green Arrow then cycles through the the Double Header range you have entered. It is nothing to do with Loco direction. I will have another look at this tomorrow before contacting HRMS. Link to comment Share on other sites More sharing options...
