andel1 Posted May 9, 2016 Share Posted May 9, 2016 Hi all Just backed up my rail master and removed it from my laptop so I can put it on a spare laptop I don't use much. What I want to know is how do I reinstall the backupI've made one I've done everything else Regards Andrew Link to comment Share on other sites More sharing options...
St1ngr4y Posted May 9, 2016 Share Posted May 9, 2016 Hi Andrew,Did you de-register the software before removing it from your laptop? If not, you may need assistance from HRMS when re-installing it on your spare laptop.To re-install it, use the link provided at the top of the Railmaster section of this Forum. Then you need to restore files which you have created (such as track diagrams, programs, locomotive settings) from the backup you have created.Ray Link to comment Share on other sites More sharing options...
Chrissaf Posted May 9, 2016 Share Posted May 9, 2016 The relevant files that you need to copy over into the Railmaster program folder are named in the version 1.64 RM manual on page 132 Link to comment Share on other sites More sharing options...
Fishmanoz Posted May 9, 2016 Share Posted May 9, 2016 Its irrelevant whether you uninstall it from the original laptop, all you need to do is deregister it from there so you can re-register elsewhere. If you didn't deregister, you will need to contact HRMS. Using the email facility in the Help screen of RM is a simple way of doing this. Link to comment Share on other sites More sharing options...
andel1 Posted May 9, 2016 Author Share Posted May 9, 2016 Yes I did deregester RM before I removed it Regards Andrew Link to comment Share on other sites More sharing options...
