Nictor Posted May 10, 2016 Share Posted May 10, 2016 Running my newly built n gauge layout with a Hornby Select and occasionally a basic Bachmann. Looking to buy a more sophisticated unit. I want two throttles. How do people rate the Hornby Elite, good or a bit dated now? Link to comment Share on other sites More sharing options...
poliss Posted May 10, 2016 Share Posted May 10, 2016 It does everything a DCC controller should do.Dated if you like controlling your locos with a tablet or smartphone. Link to comment Share on other sites More sharing options...
Fishmanoz Posted May 11, 2016 Share Posted May 11, 2016 It is a fully functional NMRA compliant DCC controller, one of many on the market. It is kept current by firmware updates (you download and install them yourself) as needed. Link to comment Share on other sites More sharing options...
Paul60 Posted May 11, 2016 Share Posted May 11, 2016 Hope not, I just ordered one ! 😮 Link to comment Share on other sites More sharing options...
Buz Posted May 11, 2016 Share Posted May 11, 2016 Hi allIt rely's on computers and programs with the speed that thechnology moves these days.It's probably out of date as soon as you open the box.regards John Link to comment Share on other sites More sharing options...
Yelrow Posted May 11, 2016 Share Posted May 11, 2016 I have not looked back since i added mine to layout. Everytime you blink, something goes out of date. I cannot fault it. john Link to comment Share on other sites More sharing options...
RDS Posted May 11, 2016 Share Posted May 11, 2016 A great controller and gives you the opportunity to add computer control using Hornby RailMaster in the future if you wish. Link to comment Share on other sites More sharing options...
96RAF Posted May 11, 2016 Share Posted May 11, 2016 I'm happy with my Elites and the Select I have as a walkabout and Railmaster as my layout controlling software. It is well known that the grass is ever greener on the other side of the fence, until you either have to eat it or cut it that is, when suddenly it isn't all you thought it was. The same goes for electronic gadgets. I have a box full of stuff that was 'all singing all dancing', which is why I bought it, until I got to use it then found out it wasn't quite as good as I thought. I've found something that I like in Hornby's DCC kit, its reliable and user friendly, so I shall stick with it, rather than chase rainbows with other brands. Link to comment Share on other sites More sharing options...
Paul60 Posted May 11, 2016 Share Posted May 11, 2016 I'm happy with my Elites and the Select I have as a walkabout and Railmaster as my layout controlling software. It is well known that the grass is ever greener on the other side of the fence, until you either have to eat it or cut it that is, when suddenly it isn't all you thought it was. The same goes for electronic gadgets. I have a box full of stuff that was 'all singing all dancing', which is why I bought it, until I got to use it then found out it wasn't quite as good as I thought. I've found something that I like in Hornby's DCC kit, its reliable and user friendly, so I shall stick with it, rather than chase rainbows with other brands. Hey Raf, I'm a newcomer to model rail as you know. But I have the Select and now an Elite on the way. After watching a few youtube videos demonstrating the Elite, I thought it looked the way to go. Link to comment Share on other sites More sharing options...
RB51 Posted May 11, 2016 Share Posted May 11, 2016 You wont regret it Paul - the Elite is a very easy to use and effective controller. R- Link to comment Share on other sites More sharing options...
Paul60 Posted May 11, 2016 Share Posted May 11, 2016 Thanks Roger Yes, looking forward to getting it. I'm enjoying the Select too for what it does. Link to comment Share on other sites More sharing options...
96RAF Posted May 11, 2016 Share Posted May 11, 2016 If you get the correct cable (round section not flat - cant remember the R number at the present) and keep your loco addresses within range you can also have a handy walkabout and your Select doesn't become redundant. Link to comment Share on other sites More sharing options...
Paul60 Posted May 11, 2016 Share Posted May 11, 2016 If you get the correct cable (round section not flat - cant remember the R number at the present) and keep your loco addresses within range you can also have a handy walkabout and your Select doesn't become redundant. Thanks Raf, The Dave Laine cable has been highly recommended. I have ordered one. Link to comment Share on other sites More sharing options...
Chrissaf Posted May 11, 2016 Share Posted May 11, 2016 For the benefit of other readers. The official Hornby Walkabout cable is the R8266https://www.hornby.com/uk-en/shop/power-control/dcc-accessories/rj12-select-elite-to-walkabout-select-lead.html..Be wary of adverts on the net selling this R number. Some sell a flat cable version. Only the round cable version is recommended. There are many posts on this forum from about two years ago relating to the pros & cons of the flat vs round R8266 cables. The round cable uses twisted pairs, the flat cable uses parallel wires. The round cable twisted pairs reject interference that Hornby found later to be a problem, hence they came up with the new improved R8266 round cable twisted pair design..Some early Hornby documentation showed the R8236 (flat) RJ12 cable as being used for Walkabouts. Some sellers still incorrectly quote the R8236 as the cable for Walkabouts. The R8236 cable should only be used with Hornby Boosters..That said, and before others point it out, there are many users using the R8236 flat cable as a Walkabout cable without issue. Not everybody is affected by interference in their particular environment. Link to comment Share on other sites More sharing options...
poliss Posted May 11, 2016 Share Posted May 11, 2016 The only problem with the Elite is that you can't plug another Elite into it, so if you want to add extra controllers, you're stuck with the two digit address of the Select. Link to comment Share on other sites More sharing options...
Nictor Posted May 11, 2016 Author Share Posted May 11, 2016 Thanks all for the info. I will get one. Not the least bit interested in running my laout from a PC, ipad, etc. Link to comment Share on other sites More sharing options...
Bulleidboy Posted May 11, 2016 Share Posted May 11, 2016 I think the Elite is fine. I'm a very basic user, and yet to explore what it is capable of. I can change my Cobalt points with no problems, although they are also switched - which is a quicker option. I have my layout and the programming track permanently wired up - and it all works well. I think sometimes there is a degree of "snobbery" with regards the appearance of the Elite as it tends to look like something from an up-market train set rather than something from a hi-tech control panel. If I had any negative comment it would be that it now costs twice as much as I paid for mine - but I suppose you could say that about many things that have been around for a while. Link to comment Share on other sites More sharing options...
Yelrow Posted May 11, 2016 Share Posted May 11, 2016 I have 2 David Laine Round yellow cables, for Walklabout. Absolutely perfect. He will make up any lenth, or standard off the shelf. The bright yellow, also makes them very visable, for us clumsy ones. Hornby, were out of stock. john Link to comment Share on other sites More sharing options...
Paul60 Posted May 12, 2016 Share Posted May 12, 2016 Thanks all for the info. I will get one. Not the least bit interested in running my laout from a PC, ipad, etc. Me either, Kinda defeats the whole purpose for me anyway. I want to escape pc's, laptops, ipads etc. Link to comment Share on other sites More sharing options...
Chrissaf Posted May 12, 2016 Share Posted May 12, 2016 Trust me I'm not knocking it, I have one of my own.........but you can always tell if the user on a YouTube video is using a Hornby Elite controller. There is this loud bassy double 'toy like' clunk in the sound track every time the presenter presses the Elite knob to do something..The sound of the clunk reminds me of the sound the switches on some of those electronic learning toys for 3 year olds make. Link to comment Share on other sites More sharing options...
Paul60 Posted May 12, 2016 Share Posted May 12, 2016 Trust me I'm not knocking it, I have one of my own.........but you can always tell if the user on a YouTube video is using a Hornby Elite controller. There is this loud bassy double clunk in the sound track every time the presenter presses the Elite knob to do something. That's all part of the tactile experience 😀 Link to comment Share on other sites More sharing options...
Chrissaf Posted May 12, 2016 Share Posted May 12, 2016 Or it could be argued that it saves putting in the cost of a speaker to provide audio confirmation feedback of button presses..... 🤑 😉 Link to comment Share on other sites More sharing options...
96RAF Posted May 12, 2016 Share Posted May 12, 2016 @chrisif you look at the Elite pcb you will see a blank space labelled spkr, i wonder what that was for. Link to comment Share on other sites More sharing options...
Fishmanoz Posted May 12, 2016 Share Posted May 12, 2016 Could only be for sound couldn't it. Very hard to get a light show out of a speaker, more than once at least. Probably abandoned the idea when they discovered all the speaker ever produced was Chris going double clunk. Link to comment Share on other sites More sharing options...
Paul60 Posted May 23, 2016 Share Posted May 23, 2016 The postman just delivered my new Elite controller. I am getting there. Just wish I had room for a bigger layout now. Link to comment Share on other sites More sharing options...
