mjb1961 Posted May 13, 2016 Share Posted May 13, 2016 HI,,,My TTS gadwall slows down on corners ,rad 2 and rad 3 ,I've had the body off and it still does it ,I can't see anything rubbing to slow it down ,if you try to crawl the loco it will stop ,if you get up some speed it will keep going but you can tell it is slowing down ,just a bit and then it speeds up on the straight ,any ideas ,the only thing I've done is Change the agorythm and adjust cv10 bemf,any ideas what could be the problem ,,thanks in advance ,,Martin Link to comment Share on other sites More sharing options...
Howbi Posted May 13, 2016 Share Posted May 13, 2016 Hi Martin........I have an 0-6-0 tank with this problem and it is caused by the centre axle of the driving wheels having little lateral freedom of movement to one side...........this has the effect of reducing the radius that can be negotiated with ease thus slowing the loco..........I think it is caused by the drive cog not being centralised on that axle.......I don't know how to rectify this problem at the moment but someone on this Forum may have a solution....HB Link to comment Share on other sites More sharing options...
poliss Posted May 13, 2016 Share Posted May 13, 2016 Have you checked the back to back distance of the wheels? Should be 14.4mm +/- 0.05mm. Link to comment Share on other sites More sharing options...
Fishmanoz Posted May 13, 2016 Share Posted May 13, 2016 I'd agree this is a mechanical problem but what changes did you make to BEMF? This is supposed to keep the loco speed constant for constant throttle under varying load. So you might try experimenting with it to see if it changes things. Link to comment Share on other sites More sharing options...
mjb1961 Posted May 14, 2016 Author Share Posted May 14, 2016 Thankyou for your replies ,3 positive suggestions there ,I will have a look at all of them today ,,,,,,martin Link to comment Share on other sites More sharing options...
trainlover23 Posted May 14, 2016 Share Posted May 14, 2016 They always do go slower on the corners Link to comment Share on other sites More sharing options...
mjb1961 Posted May 14, 2016 Author Share Posted May 14, 2016 Hi all ,once again thanks for your replies and suggestions ,it turned out to be the BEMF setting ,my lack of understanding ,I reset the decoder back to factory and then changed the agorythm to agorythm 2 and all seems well ,,,thankyou Martin Link to comment Share on other sites More sharing options...
mjb1961 Posted May 14, 2016 Author Share Posted May 14, 2016 which algorithm did you change it to ?Hi magfan ,I changed the decoder to agorythm 2 as I find that is best for smoother running and I have set the cv,s to default settings ,,,,,martin Link to comment Share on other sites More sharing options...
mjb1961 Posted May 14, 2016 Author Share Posted May 14, 2016 They always do go slower on the cornersHi trainlover,,,not on my layout ,the steamers think they are pendilino,s,,,,,,,martin Link to comment Share on other sites More sharing options...
2e0dtoeric Posted May 14, 2016 Share Posted May 14, 2016 Speed on corners (and gradients) also depends on what and how much the loco is towing. A tight curve is the same as putting the brakes on.Also, if any of your track-joiners are a bit sloppy or dirty inside, that will be costing you power as well. Link to comment Share on other sites More sharing options...
mjb1961 Posted May 14, 2016 Author Share Posted May 14, 2016 Speed on corners (and gradients) also depends on what and how much the loco is towing. A tight curve is the same as putting the brakes on.Also, if any of your track-joiners are a bit sloppy or dirty inside, that will be costing you power as well.Hi ,it was the BEMF setting ,I adjusted the value to something low ,once I reset the decoder all back to default and changed the agorythm it is now ok ,,,I know what you are saying about tight curves ,dirty rails etc but I use set track and it was slowing down on 2nd and 3rd radius ,also I keep the track very clean including the insides but thanks for pointing that out ,,thanks ,,martin Link to comment Share on other sites More sharing options...
trainlover23 Posted May 14, 2016 Share Posted May 14, 2016 They always do go slower on the cornersHi trainlover,,,not on my layout ,the steamers think they are pendilino,s,,,,,,,martinIn that case you are running them to fast and your next question will be How do I repair RXXXX Link to comment Share on other sites More sharing options...
mjb1961 Posted May 15, 2016 Author Share Posted May 15, 2016 They always do go slower on the cornersHi trainlover,,,not on my layout ,the steamers think they are pendilino,s,,,,,,,martinIn that case you are running them to fast and your next question will be How do I repair RXXXXHi ,it was meant as a joke trainlover,of course I don't run them at silly speeds ,probably half of full throttle,the slowing down on the curve was down to the BEMF ,I had lowered the cut off point due to lack of understanding but all is well now I have returned it to default,,,,,,,martin Link to comment Share on other sites More sharing options...
AddlestoneP Posted May 22, 2016 Share Posted May 22, 2016 They always do go slower on the cornersHi trainlover,,,not on my layout ,the steamers think they are pendilino,s,,,,,,,martin Link to comment Share on other sites More sharing options...
AddlestoneP Posted May 22, 2016 Share Posted May 22, 2016 Same for me, Flying Scotsman is incredibly quick over our 300 metre inner circuit. Only the APT-E is quicker! Link to comment Share on other sites More sharing options...
