walkingthedog Posted May 20, 2016 Share Posted May 20, 2016 I refuse to believe that one of you DCC users cannot recognise the make of that decoder. Link to comment Share on other sites More sharing options...
Chrissaf Posted May 20, 2016 Share Posted May 20, 2016 Looks like a "Loksound Select 6AUX", but only because the white label makes the decoder very distinctive. Not 100% definitively correct though, just a best guess..Evidence for above statement:http://www.ulrichmodels.biz/loksound-select-6aux-dcc-and-sound-decoder-8-pin-9-pin-21-pin/ Link to comment Share on other sites More sharing options...
96RAF Posted May 20, 2016 Share Posted May 20, 2016 Definitely does not match any (Hornby) Loksound v3.5s that I have, as they are 21 pin direct mount..Mine have either a round label with 38/11/MS on it or a square label with either 5552 or 2526 on it.Certainly not TTS as it has too many pins. TTS is a basic 8 pin decoder. @chris - I can't see the big square many pinned chip on these photos that your link shows. photo attached/media/tinymce_upload/b02a2f70a01462a16dd5b8234fffb98e.PNG Link to comment Share on other sites More sharing options...
walkingthedog Posted May 20, 2016 Share Posted May 20, 2016 There you go, I knew you could do it. 😆 Link to comment Share on other sites More sharing options...
96RAF Posted May 20, 2016 Share Posted May 20, 2016 My contribution is held for moderation as it contains a picture from Chris's link showing a different decoder to the wired one. Link to comment Share on other sites More sharing options...
Chrissaf Posted May 20, 2016 Share Posted May 20, 2016 I did say my suggestion was only a best guess. WTD, I think you may have spoken too soon. After blowing up the photos a little larger. The only thing that is the same between the two decoders is the white label. As Rob pointed out (before he edited out the comment), the 16 pin chip on the linked photo is missing on the OPs decoder. Link to comment Share on other sites More sharing options...
96RAF Posted May 20, 2016 Share Posted May 20, 2016 I did say my suggestion was only a best guess. To be fair Chris there are 3 pictures at that link and they all look different - harness / no harness, etc. Link to comment Share on other sites More sharing options...
RB51 Posted May 20, 2016 Share Posted May 20, 2016 Can I loan anyone my coat? 😉 R- Link to comment Share on other sites More sharing options...
walkingthedog Posted May 20, 2016 Share Posted May 20, 2016 I have great faith in you Chris. Link to comment Share on other sites More sharing options...
Chrissaf Posted May 20, 2016 Share Posted May 20, 2016 Intrigued to see what suggestion Rob is offering when his post is moderated. Link to comment Share on other sites More sharing options...
Flashbang Posted May 20, 2016 Share Posted May 20, 2016 Hi againHardly matters what make the decoder is really, it's not a Bachmann! But it certainly is a sound decoder. Of unknown manufacture.if the decoder can't be re addressed on the main by the Select, assuming this has been tried? By taking all the other locos off the main line and try to set this one locos address to something between 1 and 59, then I suggest the owner takes the loco to a local model shop or model railway club and asks if they can set its address to 3 for him. Then the Select should operate the loco on 3 and he should also be able to re address it to something between 1 to 59 Link to comment Share on other sites More sharing options...
poliss Posted May 20, 2016 Share Posted May 20, 2016 It's an ESU 54400. Loksound V4 Sound Decoder- 8 Pin. You can tell from the position of the yellow thingies and the two black whatsitsnames. 😆 Worth around £100.00. Link to comment Share on other sites More sharing options...
walkingthedog Posted May 20, 2016 Share Posted May 20, 2016 Gosh you know lots of technical terms don't you poliss 😆 😆 Link to comment Share on other sites More sharing options...
poliss Posted May 20, 2016 Share Posted May 20, 2016 That's as technical as I want to get on DCC WTD. I like keeping things as simple as possible. 😆 Link to comment Share on other sites More sharing options...
walkingthedog Posted May 20, 2016 Share Posted May 20, 2016 I'd be the same poliss. Link to comment Share on other sites More sharing options...
newcastle62 Posted May 21, 2016 Author Share Posted May 21, 2016 Hi EveryoneThe red light on the Select flashes 3 times when I attempt to programme the address on the loco.I have tested it with a Hornby sapphire decoder and from a mechanical point of view it works perfectly but not the sound (obviously).I have read all of your comments regarding taking it along to a railway model shop or club and so that is a distinct possibility. Either that or I could upgrade to an Elite but that seems a tad excessive One thing that is very puzzling is that when I put it on the energised programming track for the 1st time it went through its fall repertoire of sounds, would not move and has not made a sound since. It's almost as if a fuse has blown or something.Thanks for all your help. Link to comment Share on other sites More sharing options...
newcastle62 Posted May 21, 2016 Author Share Posted May 21, 2016 Hi MagfanThank you for your answer/advice.I suppose the question is do Invest in cakes and buns or a new controller (Elite or otherwise). The latter has come a bit sooner than I expected.I'll let you know how I get on but I guess that this is the end of the line for this particular thread.Thanks to all who responded Link to comment Share on other sites More sharing options...
96RAF Posted May 22, 2016 Share Posted May 22, 2016 Can the Select access and write to cv29, if so you can turn off long addressing and hope the short address is still at 003. Link to comment Share on other sites More sharing options...
Fishmanoz Posted May 23, 2016 Share Posted May 23, 2016 Once short address is set in CV29, it won't matter what short address the decoder is set to as now Select will be able to change it to anything you want in the range. It's that it is set to a long address that is stopping Select from programming it. Link to comment Share on other sites More sharing options...
