andel1 Posted May 20, 2016 Share Posted May 20, 2016 HI allJust reinstalled RM and all is activated so how do I put back the saved data I put on a USB stick which contains my track plan etcanRegards Andrew Link to comment Share on other sites More sharing options...
Chrissaf Posted May 20, 2016 Share Posted May 20, 2016 Just manually copy the files back into the Railmaster program folder on your PC. Overwriting any files with the same names the copy process might find there (Resource.mdb being one). Only copy the files listed on page 132 of the Railmaster version 1.64 manual......no others. I mention this, just in case you copied the WHOLE RM program folder from the old PC onto your USB stick..There are two potential RM program file locations depending upon which version of Windows you have..32 Bit Windows PCC:Program FilesRailmaster.64 Bit Windows PCC:Program Files (x86)Railmaster.The Railmaster folder will only be listed in ONE of the two locations stated above. Link to comment Share on other sites More sharing options...
andel1 Posted May 20, 2016 Author Share Posted May 20, 2016 Thanks Chris knew I could rely on you Link to comment Share on other sites More sharing options...
Augustus Caesar Posted May 21, 2016 Share Posted May 21, 2016 Great stuff Chris... couldn't have put it any better... :-) Link to comment Share on other sites More sharing options...
